d16y7 tranny swap
i have a 96 hatch with the d16y7 im wondering if i can put a ger tranny on the d16 block and if ill run into any problems or does anyone know of a better tranny that will give me better gearing and top speed
If you want better gearing and higher top speed, you'll probably be pulling the gears yourself... And as for a GSR tranny on a D block which is what I'm betting you meant to type, probably not going to happen but check links like this one for info: http://www.d-series.org/forums/trans...anny-woes.html
