Rota GT3 Spacers
Old Jan 17, 2011 | 06:23 PM
matsgsr's Avatar
Default Rota GT3 Spacers
i was wondering what size spacers i need to run for a set of 16x7 inch +40 offset rota GT3's in order to make the wheels flush with my fenders. I have a lowered '95 Integra. Any info. would be greatly appreciated.
Old Jan 17, 2011 | 06:27 PM
kaiba's Avatar
Default Re: Rota GT3 Spacers
IT'S OVER 9000!!!!
Old Jan 17, 2011 | 06:35 PM
matsgsr's Avatar
cool. not helping.
Old Jan 17, 2011 | 07:45 PM
jdmwannabee's Avatar
just measure it. it's quite simple.
measure the hub to the fender lip.
you know the offset and width of the wheel.
use those 2 numbers to calculate the size of the spacer u need to get it just under... because you don't want it to rub.
Old Jan 17, 2011 | 10:19 PM
r.wright's Avatar
id say at least a 20mm adapter spacer and some fender rollin and dumpage may be in order for you to get the fitment you desire
Old Jan 18, 2011 | 07:11 AM
alphalanos's Avatar
15x7 +40 with 15mm spacers. (front only) So use your judgement to decide if you want more or less.
Old Jan 18, 2011 | 07:17 AM
toyomatt84's Avatar
Sanji
A good thing to note, that if you go over 8mm with a spacer, you're going to run into issues with thread count on the lug studs. You'll need extended lug studs to fit much higher than an 8mm spacer safely.
FlewByU352
Sep 25, 2010 10:34 AM
aaronboy123
18
Oct 28, 2009 07:13 PM
Stock R
Aug 29, 2005 04:51 PM
IGGY
Mar 27, 2003 09:33 AM
SEA Hag
Mar 21, 2003 06:02 AM
