Causes for Burning Oil on ITR?
Old Sep 24, 2002 | 10:38 AM
vtec.dc2's Avatar
Default Causes for Burning Oil on ITR?
oil will break down under high temperatures. - i can't think of anything else but engine getting hot where oil starts to burn - nothing else could cause that, right? If ecu would cause that, would it be running too lean? - someone explain this..
wanted to ad, with larger injectors I haven't noticed loss of oil, where i would always burn it with stock injectors/ecu... does this makes sence?
[Modified by vtec.dc2, 2:58 PM 9/24/2002]
Old Sep 24, 2002 | 10:50 AM
Big Phat R's Avatar
Default Re: Causes for Burning Oil on ITR? (vtec.dc2)
It depends on the severity of use. What are we talking about here - daily driving with occasional dips into VTEC vs. street/track use with constant redline visits.
Old Sep 24, 2002 | 10:54 AM
jond's Avatar
Default Re: Causes for Burning Oil on ITR? (Big Phat R)
Oil burning is where oil gets into the combustion chamber.
Causes: Rings not sealing well, or oil leaking past valves.
Also with vtec, vtec is actuated by oil pressure. I've heard some leakage past that mechanism is unavoidable, but I really dont understand how it works so I dont know.
[Modified by jond, 2:55 PM 9/24/2002]
Old Sep 24, 2002 | 10:58 AM
mikeSONICGSR's Avatar
Default Re: Causes for Burning Oil on ITR? (jond)
I got my valve seals replaced, and then I drove 500 miles and burned 2 quarts, and the Honda mechanic told me it was normal.
Old Sep 24, 2002 | 10:59 AM
typer_801's Avatar
I tend to think it may be related to fuel. My car is burning between 2-3 quarts / 3K miles right now. For the first 1K miles, it doesn't burn any oil, then about 1500 miles it starts burning and by 2K it's gone through at least 1qt. It continues from there until I change the oil again.
I think it's fuel related, because my oil consumption really rose when I started getting more CEL 22's and the car ran in limp mode more often. I definitely wasn't driving it any harder, but oil consumption went way up. My plugs also have fouled in the past year due to this (they were new less than 12 mos ago). It's also odd that my oil has always had a strong fuel odor to it, which the dealer told me was "normal", but I was genuinely worried about since day 1.
Given that (in my case) oil consumption doesn't start immediately, but rather after the oil has been in a while, I think it's something beyond the normal wear on the motor itself. YMMV, of course.
Old Sep 24, 2002 | 11:05 AM
jond's Avatar
Default Re: Causes for Burning Oil on ITR? (typer_801)
What oil weight are you running. One possability is that oils warm weight number decreases with use. For example, my 5w30 mobil1 tested at 5w20 after 3,000miles.
Old Sep 24, 2002 | 12:05 PM
Racebrewer's Avatar
Running too rich. Gasoline thins the oil and it goes by rings and seals.
After-market air intake with improper placement (angle) of fitting that goes to the cam cover. If fitting is at a 90 degree angle on intake it creates a vacuum instead of a positive pressure and oil is sucked into intake. It lowers effective octane rating and can cause detonation, too.
John
Old Sep 24, 2002 | 12:50 PM
Tweakmeister's Avatar
Default Re: Causes for Burning Oil on ITR? (Racebrewer)
Or daily driving with constant vtec and redlining?
Old Sep 24, 2002 | 01:12 PM
sackdz's Avatar
Default Re: Causes for Burning Oil on ITR? (Tweakmeister)
Thirsty motor.
[Modified by sackdz, 5:12 PM 9/24/2002]
Old Sep 24, 2002 | 01:59 PM
typer_801's Avatar
5/30 Mobil 1
I also ran 10W/30 Mobil 1 with the same results. I'm going to switch to Valvoline Max Life 5W/30 on my next change. We'll see what happens after that.
Old Sep 24, 2002 | 02:11 PM
sil's Avatar
sil
5/30 Mobil 1
I was still burning oil with the exact same switch.. from mobil1 5w30 to valvoline maxlife 5w30..(but i've got a b16a2)... of course now the burning oil won't hurt the wallet..:0
Old Sep 24, 2002 | 03:28 PM
Smitdog's Avatar
Umm dont burn a drop, and #0120 sees that alot!!
Old Sep 24, 2002 | 04:31 PM
vtec.dc2's Avatar
1.
i can't seem to understand that one.. i can understand how gasoline would thin the oil..
but lets say there's nothing wrong with seals. rings.. how would running rich break though seals?
2. How does it make sence in my case?
Old Sep 24, 2002 | 07:22 PM
vtec.dc2's Avatar
ttt
Old Sep 24, 2002 | 07:35 PM
Dirt's Avatar
http://www.bobistheoilguy.com then go to forums and dig around.
Old Sep 24, 2002 | 07:52 PM
onyx00's Avatar
Default Re: Causes for Burning Oil on ITR? (George Knighton)
I use Mobil One and I am down about half a quart close to when I am due for an oil change.
Old Sep 24, 2002 | 07:59 PM
vtec.dc2's Avatar
Default Re: Causes for Burning Oil on ITR? (onyx00)
o.k.. i should of added that i used regular oil (5w30) before and after...
[Modified by vtec.dc2, 12:03 AM 9/25/2002]
Old Sep 25, 2002 | 07:53 AM
dimsum's Avatar
1. Running too rich. Gasoline thins the oil and it goes by rings and seals.
I think that if you run rich, the extra/additional gas will seep past the seals, diluting the oil. The thinner oil will also seep past seals easier, allowing it to burn in the combustion chamber. I'm not 100% sure about this, but I do know for sure that running rich will dilute the oil and cause your engine to burn oil.
Larger injectors will help you burn less oil or stop burning oil all together. With larger injectors, you can run a lower fuel pressure. A high fuel pressure (>50) causes your engine to burn more oil. If you get larger injectors, you can give your engine the same amount of fuel, but at a lower pressure.
If you have a FPR and a fuel pressure gauge, check to see what the pressure is set to. Unless you have a lot of engine work, the pressure shouldn't be higher than ~46. If you need to set your FPR higher than that, you should consider getting larger injectors.
Old Sep 25, 2002 | 08:48 AM
H-PIMP's Avatar
Default Re: Causes for Burning Oil on ITR? (dimsum)
Possible causes for excessive oil cosumption:
1. Premature use of synthetic oil (a biggie on this board)
2. Improper break-in period (i.e. bouncing off the rev limiter in a new car)
3. 1 or more defective rings from the factory (rare, but does indeed happen)
Old Sep 25, 2002 | 09:08 AM
roydogg's Avatar
Default Re: Causes for Burning Oil on ITR? (H-PIMP)
I've got my valve seals done awhile back too still burnin oil but not as much. must be the rings. I went through about 3 oil changes in 3 months always having to top it off 1 quart a week while using 5w30,10w30 mobil 1 synthetics and was still burning oil. LAst month I tried 15w50 mobil 1 synthetic in my teg and I race heavily every weekend and I had just added about a quart today. I have to drive hard atleast everyday a couple of times a day just can't help the feeling of torque while I'm driving. But I think it help my pockets out a bit just make sure you let the car idle til it's warm. pretty thick
Old Sep 25, 2002 | 09:19 AM
uncleben's Avatar
Mobile Freaking One!
explain please... i use mobile 1 5w30 and i too burn oil.
also, at several autocrosses it's been mentioned to me a poof of light white smoke from my exhaust when launching hard in 1st gear
Old Sep 25, 2002 | 09:52 AM
vtec.dc2's Avatar
thanks, my fuel pressure is at 44psi.. i could have it lower.. since i have 370cc
Old Sep 25, 2002 | 10:22 AM
Hooch'n's Avatar
Vtec never hurt anything................Vtec and redline all the time
Old Sep 26, 2002 | 11:41 AM
dimsum's Avatar
Default Re: Causes for Burning Oil on ITR? (uncleben)
Mobil 1 is a synthetic oil, so it is very thin. The thinner the oil, the easier it is to seep past the piston rings, enter the combustion chamber, and get burnt up.
Regular oil (non-synthetic) is thicker, so it won't seep past the rings as easily.
Another option is to use really thick synthetic oil, like 10W50 or something like that.
Old Sep 26, 2002 | 12:52 PM
RagingAngel's Avatar
I've mentioned this in the past....
my car makes good compression numbers and has less than 2% variation when doing a leakdown test....
I've used Mobil 15W50 on lapping days and I still burn it.... infact when using a N1 style exhaust system....(straight thru muffler) my car can blow smoke rings....
I suspect it's the PCV now, since I can actually SEE the intake manifold sucking oil out of the catchcan (non baffled)
RA who isn't as worried as he use to be....
