Bulbs for Instrument Cluster.
I was wondering if there's a way to just buy bulbs that are bright white that will fit where the 5 stock bulbs slide in and twist in the Tach/Speedo Cluster. I've seen talk about putting LEDs in with modification, but I dnt really need to modify it much. The stock bulbs are that ugly dome light orangish/yellow color and I did the dash mod to change all the lights from green to blue. Problem is those bulbs are making the blue have a tinge of green with it's yellow/orange light. Yellow+Blue= Green. I want something that's just white, and brighter to light the blue up much more. Any ideas? Or would the LED mod be the best way to go?
I donīt know about LEDs, but aren't the 'orangish/yellow colors' just a plastic wrapping they have covering a perfect bright white bulb?? Have you taken those bulbs out and check if it's just a matter of removing that?
