NC 1995 Honda Civic DX Hatch - Phantom Gray - B18C1 - Highly secured - Etc
- 1995 Honda Civic DX Hatchback
- 170,000 Miles on Chassis
- Unknown on engine, estimated 140,000 - 150,000
- Hot Heat
- Cold A/C
- Clean Title
- Daily Driven / No mechanical issues / Garage kept
- Email:itslogz@gmail.com
- Winston-Salem, North Carolina
- $5500
NO TRADES NO TRADES NO TRADES NO TRADES
Engine:
- Stock B18C1 (Perfect compression numbers)
- Y21 B16 Non-LSD Transmission NO GRINDS.
- Hasport 62a billet motor mounts
- AEM intake
- Stock header / Heatshield
- Stock exhaust piping with a OEM aftermarket replacement muffler.
- Fully tucked engine bay. Battery relocated to trunk. Fusebox under dash
- Just replaced axles with mint OEM Honda used units.
- Recently replaced cam seal / vtec sol. seals / rotor button / plugs / wires with OEM / NGK plugs
Interior:
- Light gray
- Integra GSR black cloth seats
- Nardi Classic 360mm steering wheel
- JDM EG6 cluster
- JDM amber clock and climate control
- Mugen formula shift ****
- B&M dual bend short shifter
- All interior intact
- Entire interior removed and surfaces lined with FatMat.
Suspension:
- Stock struts / cut springs (I know, right.)
- Ksport rear LCA's
- Skunk2 front Camber kit
- Skunk2 Rear camber kit
- Stock rear drum brakes / front discs
Exterior:
- Phantom Gray - PPG Paint. Repainted in 2005. 3 Coats of clear was used.
- Extremely clean body, few tiny pressure dents on the front of the hood from push closing, body has 0
- dings/dents/waves.
- Wings west spoon style duckbill w/ LED
- APR GT3 carbon mirrors
- OEM Clear corner lights
- OEM antenna delete blockoff
- Depo fogs w/ OEM switch
- Stock HX wheels / Good tires
Security:
- Python 990
- Keyless entry (driver door only, passenger has no actuator)
- DEI 520t backup battery
- DEI 507m tilt sensor
- 2x DEI 513t piezo sirens mounted in vents
- DEI 506t audio sensor
- fuel pump / ecu kill
- Headlight flash / horn honk
- Theft isnt going to be a issue what so ever with this car.
Audio:
- Clarion DXZ775USB headunit (Ipod input / Aux input / USB Input)
- Polk DB651 6.5" door speakers
- MTX audio thunder 564 amp
The Bad:
- The engine bay wasnt repainted, but remains phantom gray as well, just not as blingy.
- Stock struts / Cut springs suck, although no bouncier than any other cheaply lowered Honda.
- A/C needs to be vacuumed / recharged due to recent O-ring leak, now replaced.
- Minor scrapes along front bumper bottom, due to previous installed lip, will be covered with one reinstalled
Thanks. If this doesnt get sold for something im satisfied with or anything its gonna be getting parked soon enough and a bay make over / different engine configuration thrown into play. Along with some other jank of course.
Aloha..
Like your civic..
How does she REALLY run,will it make to California ?
*** MANY more picts.PLEASE..****
What airport is nearest to you?
Thanks many..
OrcaHot@yahoo.com
Like your civic..
Thanks many..
OrcaHot@yahoo.com
Aloha..
Like your civic..
Thanks many..
OrcaHot@yahoo.com
Like your civic..
Thanks many..
OrcaHot@yahoo.com
Uhhhhhhhh if youre serious, PM me or email me.
Aloha..
Like your civic..
Thanks many..
OrcaHot@yahoo.com
Like your civic..
Thanks many..
OrcaHot@yahoo.com
^^ lol yeah to anyone who wants to drive cross country in a lowered swapped honda with a b16 trans gets a brass ball award from myself.
Bump
I removed the things from "the bad" list that are going to be fixed within the next week. Including axles, A/C orings, and the throttle cable/bracket.
itslogz
Southeast (Sales)
26
Feb 10, 2011 09:28 AM
