92 not sure whats wrong
Old Jan 17, 2011 | 01:38 PM
velezj2020's Avatar
Default 92 not sure whats wrong
i have a 5 speed it recognizes the gears. but has no catch when in the gears..stopping the car from going anywhere. the pedal still feels stiff like it should catch but it doesnt plz give feedback
Old Jan 17, 2011 | 02:30 PM
lazlong's Avatar
Default Re: 92 not sure whats wrong
You have a hydraulic clutch. Check the master cylinder, slave cylinder, and the lines for leaks. Sometimes there's an internal leak in the slave cylinder that you can't see and replacing it takes care of the problem. To help illustrate, #7 is the master cylinder (on the firewall) and #10 is the slave cylinder (on the tranny): http://www.hondapartscheap.com/south...t=0&quantity=0 Although it looks like it's discontinued. Try local CL, eBay and here for nationwide salvage: http://www.car-part.com/ Good luck.
EDIT: I found repair kits and the cylinder themselves here: http://www.rockauto.com/
Old Jan 18, 2011 | 02:53 AM
dafang's Avatar
If the clutch pedal feels right, then I would think that the clutch plate is worn out. If the clutch plate is worn, you should have felt the transmission slipping recently. I have replaced my slave cylinder twice, both time the clutch pedal had no resistance, and would not return to its normal position.
Old Jan 18, 2011 | 08:32 AM
velezj2020's Avatar
it was slipping really bad right before it went.. will this effect my transmission in any way?
Old Jan 18, 2011 | 09:48 AM
dafang's Avatar
You most likely need your clutch disk and pressure plate replaced. I would suspect that this is a job that is beyond your abilities to do yourself. Parts are around $100 to buy. To have done at a transmission shop would probably be $500 to $600.
Old Jan 18, 2011 | 11:11 AM
lazlong's Avatar
Check for leaks first, it's a whole lot cheaper and easier to check for a leak before spending $500. Hell, what's $10-20 when you might end up spending $500?
tato1983
Dec 11, 2007 05:52 PM
osiris1741
Jan 24, 2007 07:27 PM
Schurke
Nov 24, 2005 05:16 PM
siregcivic
Oct 16, 2005 07:55 PM
Accord15
Oct 13, 2002 08:57 AM
