98 Accord tranny probs
I have a 98 EX auto 4-cyl sedan with 162K on the engine. I had the tranny rebuilt a few years ago with no probs and recently before I had the transmission fluid flushed a few weeks ago reverse would always shift in hard. No matter from what gear (park or drive), reverse would shift hard.
Post-flush I have not experienced the hard shift anymore but now I am getting a spike in RPMs when I accelerate sometimes, with the car not responding to the pedal and it seems to happen more frequently when the car is cold and b/w 2nd-3rd gear. The engine revs up but the transmission is late to respond to the pedal. The RPMs suddenly drop and then away I go.
I guess these would be gear slips, with the loss of acceleration b/w 2nd-3rd gear with only a spike in RPM with no response to the accelerator. Is this in fact a tranny problem or something else?
Thanks in advance for any help.
I don't know what is causing your problem, but I do know that Honda does not recommend this type of transmission flush - someone out there can probably point to the TSB they issued about this.
Wow, did not know that a flush is not recommended. I went to a local Jiffy Lube for an oil change and on the up-sell I figured why not along with a coolant flush. Fail on my part.
The place is closed today for MLK, but the service log on the receipt states "multi-vehicle ATF".
I gather only changing out the fluid is what's usually performed correct?
Cashpoboy
Apr 17, 2008 05:07 PM
jamiesmith
Jul 20, 2007 06:09 PM
