great dd for sale
MOVING TO NORTH CAROLINA CANT TAKE IT WITH ME PRICE IS 3000 I NEED THAT TO BUY A NEW CAR
I HAVE A 1995 CIVIC DX WITH EX ADD ON'S IT IS BLACK JUST RECENTLY GOT PAINTED THE COLOR IS NIGHTHAWK BLACK PEARL. IT IS LOWERED ON SLIP OVER COIL OVERS BUT I CAN PUT STOCK SUSPENSION BACK ON. I JUST PUT A STOCK EXHAUST BACK ON. THE MOTOR IS THE STOCK MOTOR THAT CAME WITH THE CAR. PERFECT FOR A SWAP. THE TRANSMISSION IS OUT OF A 95 CIVIC EX FOR SHORTER GEARS. IT DOES HAVE A SHORT SHIFTER IN IT. IT HAS EX FRONT BRAKES EX MASTER CYLINDER EX GAUGE CLUSTER WITH THE TACH. IT DOES HAVE TINTED WINDOWS. NO A/C NO POWER STEERING. IT DOES HAVE POWER WINDOWS POWER LOCKS OFF OF A EX CIVIC. I HAVE BLUE LOWER CONTROL ARMS ON THE REAR ALSO A REAR LOWER TIE BAR AND A FRONT UPPER STRUT BAR. IT HAS FOGLIGHTS THAT ARE HOOKED UP.
RECENT MAINT.
VALVE SEAL IN THE HEAD VALVE LASH ADJUSTMENT
HEAD GASKET WATER PUMP TIMING BELT
UPPER AND LOWER BALL JOINTS TIE ROD ENDS
NEW FRONT CAMBER KIT
IF YOU HAVE ANY QUESTIONS GIVE ME A CALL OR TXT ME BUT TXTIN IS EASIER TO GET AHOLD OF ME MY NAME IS KRIS MY NUMBER IS 240-538-5282
RECENT MAINT.
