Transmission & Drivetrain Gearboxes, Differentials, Clutches
tranny swap
Old Jan 17, 2011 | 10:51 AM
Bullharley's Avatar
Default tranny swap
I have a 1992 honda civic ex, hydrolic tranny d16z6 motor . Want to know if I change it to cable will a 89 through 91 si tranny would fit the civic
Old Jan 17, 2011 | 12:14 PM
SI-r rex racer's Avatar
Default Re: tranny swap
what do u want to do now??
Old Jan 17, 2011 | 01:11 PM
if the civic is a cable clutch then yes
Old Jan 17, 2011 | 02:17 PM
Bullharley's Avatar
A friend and I were discussing the possibility. He has a pedal cluster cable and tranny to transfer it over to cable. My ex tranny is not geared for racing circle track but the si is and instead of paying 1500.00 dollars for a built tranny this would be a way cheaper move. I looked and compared the trannies and they looked the same but I thought I would ask just to make sure. Anything else that I need to keep in mind? Thanx
Old Jan 17, 2011 | 03:10 PM
swap the clutches t bearings presure plates because no matter how good the trans is the clutch isnt used to the motor so the clutch will basicly wear quicker
Old Jan 17, 2011 | 06:58 PM
arronabraham's Avatar
i have a 96 civic with a d16y7 im wondering if i can swap a gsr tranny onto this block will i run into any problems and is it even possible
Old Jan 17, 2011 | 08:53 PM
nope unless u got a adapter plate you can buy myu trans i got tho its a built d16z trans and its hydro
Old Jan 18, 2011 | 07:23 AM
94EG8's Avatar
Seagull Management
They're geared almost exactly the same. If you're going to go through all that work at least make it worth your while and swap in a CG tranny out of an '86 - '89 Integra.
92 teggy
Feb 12, 2010 05:45 PM
GuitarPunk015
Jul 9, 2008 03:36 PM
JDMracer17
Nov 9, 2005 08:33 PM
makoto
Jun 26, 2005 10:21 PM
D16Z6racing
May 14, 2002 05:15 PM
