Suspension & Brakes Theory, alignment, spring rates....
Camber kit adjusted...steerings weird though??
Old Jan 17, 2011 | 08:52 AM
k_lude's Avatar
Default Camber kit adjusted...steerings weird though??
my hatchback has powersteering still i recently adjusted my camber kit cause tires kept rubbing no more rubbing but steering is weird car reacts to my steering more but the steering wheel turns to quick dont really know what it is if its a good thing or not...also does that mean im in need of an alignment
Old Jan 17, 2011 | 09:04 AM
kyden's Avatar
Default Re: Camber kit adjusted...steerings weird though??
um yeah an alignment is necessary when changing any suspension angle.
Old Jan 17, 2011 | 12:09 PM
Grohe's Avatar
agreed
Old Jan 17, 2011 | 12:47 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I'm guessing you added negative camber (moved the camber kit inwards) to keep the tires from rubbing. What you have done now is introduced toe in on the front end of the car. Toe in can generally help keep a car going in a straight line better, but usually isn't that great for cornering performance. Also you have no idea what sort of camber angles you have now, or what toe angles you have. I'm sure everything is different side-to-side.
You really need to get it on an alignment rack ASAP.
wolf95
Suspension & Brakes
12
Nov 10, 2009 05:01 PM
themorphious
Suspension & Brakes
Mar 31, 2006 05:32 PM
gsr dood
Dec 28, 2005 11:16 AM
VspecSiR
Suspension & Brakes
Dec 27, 2005 08:28 AM
JDMhatchback20
Nov 17, 2004 09:06 PM
