4 wire o2 sensor
Ok I have a 90 crx si with a b18b1 obd1 pr4 ecu and I was wondering if anyone knew how to wire up a 4 wire o2 sensor I can't seem to find anything about it. Thanks
I am also getting a cel code 4 crank position sensor does anyone know where this is located I had tried a new dizzy and ecu and it didn't help and I can't figure out where its at in the dizzy or on the block thanks
Ok I'm not sure where to wire up my o2 sensor on the jumper harness I bought the car and it was like this guess its true don't buy someone elses project but for the crank position sensor I tried a new dizzy and ecu and still got the code 4 that's why I was asking is there any certain place for o2 sensor wiring and thank you for the help I'm just trying to get my car out of lim
I wrote this with an expectation of u knowing some of the terminology....
The o2 signal is the one that comes from the old 1 wire o2 sensor plug.
as for the ground, i normally wire that up to the bulk of grounds that are grounded to the thermostat.
if u are completely obd1 the correct way u should have a plug that looks like this
that plug is ur 12v source if u dont have it. i would look for a good ecu controlled 12v source
the o2 sensor heater should be a loose wire on ur ecu jumper harness. if not u should wire the o2 sensor heater up to ecu PLUGA PIN LOCATION 6
hope it helps brotha
Compliments of rywire.com
http://www.rywire.com/catalog/articl...?articles_id=1
bobcollege
15
Mar 22, 2018 10:12 PM
phbrush
27
Dec 17, 2014 07:25 AM
