check engine?! in my obd1 ef d16z6 ef
ok so car was working fine and didnt have any problems ran good vtec hit and i just smogged it to!
well now it turns on the CEL when it hits 5 k and vtec dont engage so im wondering what can it be? it also kinda has a lag and boggs any help? thanks much appreciated
why do ppl post that they have a CEL and a crappy running car yet NEVER diagnose the ECU codes! ok sooo you have an engine light on. how bout checking the trouble code? maybe itll tell you the problems
My thoughts EXACTLY!! I don't want to be captain obvious but if you have a CEL then common sense should tell you to find out what the code is.
The three fast blinks are code 3 for map sensor is it hooked up right are the wires cut is the map sensor any good???? And code 7 is tps. Is your tps any good look for cut wires. But honestly try switching the tps plug to the map sensor and the map sensor plug to the tps I think you have them both mixed up a lot of people do that get them confused they are both the same style 3 wire. Plug I bet that fix your problem if not look for bad wiring
Now you need to find out if these two components and the ECU are in good working order. Get a hold of the service manual and run through the troubleshooting procedures for MAP and throttle angle sensor.
93grayeg
14
Apr 17, 2011 10:04 AM
Chronicsinners
Feb 2, 2005 03:54 PM
