another Dc cluster in a ef question...
Old Jan 16, 2011 | 07:19 PM
efjones9's Avatar
Default another Dc cluster in a ef question...
90 civic is the car. i was wondering if someone had the correct wiring diagram they have used to perform this cluster swap. ive seen some of the ones that are up thru google search but i compared them and some dont seem to match. anyone have a 100% accurate one ? thanx
Old Jan 16, 2011 | 07:43 PM
gnxpro24's Avatar
Default Re: another Dc cluster in a ef question...
yea I did the cluster swap in my car. worked perfect. if youre car is an 88-89 then ur good to go. Im actually trying to make my car work with the door ajar light right now ne way heres the link. https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/here-pin-outs-88-89-civic-gsr-integra-cluster-swap-2700215/ only thing that might? not work is my brake light always flashes for a couple seconds when the key is clicked to the 2 position
what I did is I pulled the dash and then wired it/soldered it together in my house
edit: wow just realized you posted 1990 civic
Old Jan 16, 2011 | 07:51 PM
gnxpro24's Avatar
heres one I found. https://honda-tech.com/forums/showth...ntegra+cluster
if I were u I would message d16sihatch he made a write up https://honda-tech.com/forums/members/d16sihatch-999534687/
efjones9's Avatar
lol i just messaged u thanx bro
Old Jan 16, 2011 | 08:52 PM
efjones9's Avatar
i ran across some problems trying to verify the position and function of a few wires
on this diagram B9-charge warning light/b10 voltage regulator/a2 pgm-fi plusar? que??
https://honda-tech.com/attachment.ph...1&d=1261539141
on this diagram these didnt exactly match up
http://crxcommunity.com/viewtopic.ph...ote=viewresult
Im confused lol any help?
Old Jan 16, 2011 | 09:11 PM
gnxpro24's Avatar
did u remember that that first link is for 88-89 clusters? the wiring is in diff pins 90-91
Old Jan 16, 2011 | 09:36 PM
D16SiHatch's Avatar
the pinout and lots of other good info is located within the "cluster lets see them" thread.
https://honda-tech.com/forums/showpo...6&postcount=21
Old Jan 16, 2011 | 09:39 PM
k20rex's Avatar
i found this here on honda tech when doing my cluster swap
Old Jan 16, 2011 | 09:40 PM
gnxpro24's Avatar
there was a door open light on the 90-91?
Old Jan 16, 2011 | 09:47 PM
efjones9's Avatar
thanx guys
Old Jan 17, 2011 | 05:31 PM
gnxpro24's Avatar
does ne body no how many amps one of the lights in the back of the gauges is putting out? one of the ones for door ajar light etc
Old Jan 18, 2011 | 06:44 AM
efjones9's Avatar
The cluster light? Ill check when I install. Do u want to run it to a fuse to it?
Old Jan 18, 2011 | 11:41 AM
gnxpro24's Avatar
well I figured out a way to wire up a door ajar light for 88-89 sedans and crx/hatches. Im running it on a 10 amp fuse but with that little gauge light it will never break if something goes wrong?
Old Jan 18, 2011 | 01:14 PM
Clipsed's Avatar
Wait is the guy that sells wiring harnesses asking how to do wiring holy **** I hope nobody was stupid enough to buy product from someone that doesn't know how to read wiring diagrams from a helms manual!!
Old Jan 19, 2011 | 04:34 AM
efjones9's Avatar
Don't have a helms manual. Keep ur dumb *** comments to ur self. I am ase cert. And an engineering student . So I am more than capable of reading of any diagram that I have. But I don't have one. So if u wana help out be my guest. If not get off the thread. Cuz u making ht look bad with all of ur hating. That's why people call it hater tech cuz of bastards like u
Old Jan 19, 2011 | 04:36 AM
efjones9's Avatar
God I hope the mods will clean up clipsed negative comments. Starting to get me mad
Old Jan 19, 2011 | 04:40 AM
efjones9's Avatar
That sounds good. I dnt think it needs to be fused with a 10amp maybe a 5. But test it and let us know
Old Jan 19, 2011 | 09:06 AM
Clipsed's Avatar
With all those harnesses you sell you can't afford to buy a helms manual!?? Lolz that's some sad ****! Goes to show ase certification taught you nothing... half assing ****. Id hate to see what you are going to "engineer"... watch out everyone!
Old Jan 19, 2011 | 11:43 AM
efjones9's Avatar
Lol @ wayne
Old Feb 24, 2011 | 02:44 PM
gnxpro24's Avatar
theres nothing there that would make the light inside the hazard switch light up
90civicbns
Sep 30, 2013 09:05 AM
tast2s
Aug 23, 2012 08:21 PM
SolAssassin
Apr 10, 2008 05:41 PM
jweeks
Aug 5, 2007 11:17 AM
dubb
Aug 8, 2006 02:58 PM
