4 door rebuild
Old Jan 16, 2011 | 05:30 PM
mpt.ed3's Avatar
Default 4 door rebuild
hi im new here. i have a 91 civic i just bought. i overpaid for it and i know i need some work done. no worries tho im up for anything. i have picked up a spare d16 block i want to rebuild and replace my current block with. hopefully i can use my d15 head with my new spare. ill keep updating as i go along.
here are some pics to sum up my car.
Old Jan 16, 2011 | 05:34 PM
Nooch's Avatar
Default Re: newb for sure
Nice, how much did you pick it up for, if you don't mind me asking?
Old Jan 16, 2011 | 06:21 PM
KINGVEM^^ED6's Avatar
doesnt look to bad how much
Old Jan 18, 2011 | 05:25 PM
mpt.ed3's Avatar
i paid 2900
Old Jan 18, 2011 | 05:31 PM
wow thats alot what were the specs BEFORE u tore it apart?
Old Jan 19, 2011 | 08:01 PM
mpt.ed3's Avatar
nah i paid 1300.. might as well have been 29 tho... oh well lesson learned. now its time to learn and have some fun! kingvem what specs are you referring to?
Old Feb 27, 2011 | 08:45 PM
mpt.ed3's Avatar
im still commuting and savin money. ill keep everybody updated
Old Mar 9, 2011 | 07:29 PM
mpt.ed3's Avatar
new plans. buy y8 head and try my hand at conversions... fun! oh yeah alternators suck
Old Apr 27, 2011 | 05:01 PM
mpt.ed3's Avatar
wow finding a p28 is hard.... mainly the ridiculous prices!!
Old Jul 14, 2011 | 08:47 PM
mpt.ed3's Avatar
what a disaster
Old Jul 14, 2011 | 09:04 PM
EL Vap133's Avatar
Nice project, keep up the good work!
Old Aug 7, 2011 | 11:22 AM
mpt.ed3's Avatar
shes running now but after a change of plans. i had to buy a jdm d15b nonvtec because i couldnt swap the water coolant inlet line from the b2 to the a6. so now im just waiting for more money to continue the vtec addition. live and learn! even with the cost of the parts and motor im still saving money over taking it to a shop and having them replace piston rings.
Old Jan 2, 2012 | 02:19 PM
mpt.ed3's Avatar
still at it. in fact i just did axles this past weekend. here are the pics.
loosen lugs and spindle nut.
loosen crown and damper bolt/nut.
once ball joint is loose and axle removed from hub this is how it looks.
everything reinstalled, minus spindle nut and crown nut.
this image shows how i had to seperate ball joint. place and raise jack on lower control arm. place wrench between lower control arm and hub. release pressure from jack. if wrench, or piece of all thread in my case, is not ground at this point, step on assembly. it should seperate the ball joint. ( disclaimer: i in no way endorse this method as OSHA safe.)
just another view of the last image.
oh yeah, buy new cotter pin for lower ball joint, tranny fluid, replace axle seals, torque everything down, and have fun. yeah.
Old Jan 2, 2012 | 02:40 PM
90civic-ZC's Avatar
You could've just bought a ball joint popper and it would've been soooo much easier than what you had going on.
Old Jan 2, 2012 | 02:55 PM
mpt.ed3's Avatar
i could have and i am still thinking of doing it the next time i have to replace axles. i plan on staying in the d series for a while so i figured buying one would have been a waste of money..
Old Jan 2, 2012 | 02:57 PM
ryanmh22's Avatar
ik a place in kc that you can get a p28 for like 40 bucks
Old Jan 2, 2012 | 10:44 PM
88LsRex's Avatar
Or you could have smacked the control arm with a hammer. pops out easy that way sometimes.
- Auto p28's are easier to find, just convert it, i have a pr4 thats chipped and has vtec. for sale ahah but its obd0
Old Jan 3, 2012 | 01:31 PM
whited's Avatar
CRX God
I prefer hitting the control arm with a hammer. Using a balljoint fork usually rips the boot. What I do is put a pry bar wedged in, and press down on the control arm as I hit the arm. Either I have someone press down on it, or I use my feet and lay on my back. Use both hands to hold the hammer and swing has hard as you can.
Old Jan 3, 2012 | 01:43 PM
4drEF's Avatar
Keyboard Humorist
Forks are not really all that friendly to Hondas.
Pitman pullers make it easy
Old Jan 4, 2012 | 08:29 PM
mpt.ed3's Avatar
Nice lookin tool you got there. I found a p28 for like 80 a while back. Timing belt and o2 sensor are all i need to finally start swappin heads
Old Jan 6, 2012 | 05:23 PM
mpt.ed3's Avatar
motor mount inserts this weekend. here we go...
Old Apr 9, 2012 | 11:06 PM
mpt.ed3's Avatar
lowered, check. vtec, no check. im lazy and broke. not a good combo
Old Apr 10, 2012 | 07:09 AM
4drEF's Avatar
Keyboard Humorist
ECU codes?
Old Apr 15, 2012 | 01:57 AM
HotCheetos's Avatar
reuse your d15 head and get a6 cam&camgear, most D series parts are interchangeable
Old Dec 30, 2012 | 04:39 PM
mpt.ed3's Avatar
been a while since i posted here. still cruising but doin mostly maintenance work on the saloon. 150 miles a day aint no joke on a 20 year old car!! gettin to know bolt sizes and thread pitches by look and feel tho. ha.
