Passenger Rim
Ok heres what happened driving home from turned a corner too fast car swong around and i ended up on a curve my passenger rims got dinged up and also tie rod was bent well replaced the tie rod got the car aligned my rim still is not straight up and down it towed in at the bottom any clue what needs to be replaced thanks in advance.
They shouldn't have done the alignment if your suspension is F#@ked up. They should have told you that something needed to be replaced before it went onto the alignment machine. If it is toed in enough for you to notice it could be the lower control arm is bent.
followthadollar
Apr 27, 2010 08:32 PM
