oil cooler with 99SI slim radiator ok for turbo?
can i Utilize the oil cooler from a 99si auto? it comes with the in and out for oil cooler on the radiator itself...
are you talking about the trans cooler fittings on the radiator? The engine is going to produce more heat taxing the small radiator, i dont think you want to add engine oil heat into that mix. generaly the engine oil should be fine without a cooler unless your turbo and autocross the car at which point expense shouldnt be spared and a proper oil cooler should be run
But, Honda uses the same radiator, with a couple fittings for the automatic versions of other trim levels. Even if it were not originally installed, somewhere along the way it could have been.
Just get a proper oil cooler. They're not that expensive and you'll get better cooling. On that note, get a new dual core radiator also. They're like $40 on eBay.
Jonathan_ED3
Jul 25, 2003 10:01 PM
