Transmission & Drivetrain Gearboxes, Differentials, Clutches
will a 98 acura tl transmission fit a 2000 acura tl?
Old Jan 15, 2011 | 08:20 PM
Smok3o3's Avatar
Default will a 98 acura tl transmission fit a 2000 acura tl?
As titles says, I found a 2000 tl with a slipping transmission but still runs. I have not drove it yet but the owner told me the did a flush on transmission at 90k car now is 167k and I know flush is bad for acura/honda. So Im thinking I might have to replace or rebuild the tranny. I found a 98 but not sure would transmission fit as the style changed in 1999.
Please help thanks!!
Old Jan 16, 2011 | 08:17 AM
Smok3o3's Avatar
Default Re: will a 98 acura tl transmission fit a 2000 acura tl?
or maybe an rl transmission?
Old Jan 16, 2011 | 01:41 PM
night's Avatar
all just accord stuff. do a simple check of harness plugs. same number of plugs and same number of pins and you should be good to go. only major diff would be 4 vs 5 speeds.
I couldnt say more than that for you. we rebuild autos but I don't pay that much attention .
Old Feb 20, 2011 | 09:54 PM
Smok3o3's Avatar
Thanks for the reply I was thinking about buying a tl with bad tranny and found a 98 tl tranny.
Old Feb 21, 2011 | 06:31 AM
94EG8's Avatar
Seagull Management
Doesn't fit. Must be an '00 - '03 transmission. Please note that these transmissions had an extremely high failure rate. So if you haven't already bought it take that into consideration.
ipihuc
Acura TL, RL & ZDX
Dec 28, 2010 07:15 PM
southparkosm
Aug 28, 2009 06:34 PM
JDMTURTLE
Acura TL, RL & ZDX
Sep 3, 2007 04:57 AM
eggrock
Acura TL, RL & ZDX
Jan 12, 2004 11:06 PM
Pineapple Devil
Nov 8, 2002 06:31 PM
