Eibach Springs, Uneven Height Issue
Okay so Ive got Eibach Sportline springs, with koni yellows. Love the suspension, however the front sits a bit higher than the back, n just looks weird. Most ppl come up to me and tell me to just cut the springs, but i dont want to ruin these springs. Any suggestions?
Rear trailing arm bushings/RTA
Youd be supriesed how easy it is to get the springs mixed up.
But I think if the springs were wrong, the front would be slammed and the rear lifted?
Also, sence you have koni's they have adjustable perches, are they even front and rear?
Make sure you assembled the front Koni shocks correctly. It's easy to install the front perches upside down, making the car about 1" higher in the front.
The rear perches look like a cup facing up. The front perches look like a shallower cup, but they must face DOWN, with the springs fitting over the top of and around them.
I bought the car with the suspension work all done, so i never thought about them doing it wrong. ill look into it today,
Ive attached a pic of the rear, are those the perches you mentioned?
Yep, the front perches are most definitely installed upside down. Rears are fine.
Flip those front perches around and you'll be good. Be sure to get it aligned afterwards since the front will sit lower and the tires will toe out more than before.
You just MADE MY DAY! im about to go ripe it all apart and get it done...cant believe i drove around like that for a year!
lol my buddy did the same on his 96 hatch when he first installed his Konis. We changed them around in my driveway back in the day.
*edit* here's a pic of my Konis with the perch installed correctly.
So finally did the flip, the day b4 the snow storm n now i regret it...lol it looks hot as hell...except it bottoms out everywhere...lol i shouldve done this in the summer but w.e.
here are some pics.
here are some pics.
Just push on the break in the clip with a flat screwdriver to work it out of the groove and move it to the next groove.
You may be back up near the height you were at before, though.
i think i may do that and put it back low once the weather gets warmer.... my flex pipe is one inch off the floor...smh
Yeah that lowest perch setting is meant more for taller OEM springs. I run my OEM GSR springs up front on the lowest Koni perch setting.
now get it aligned.
neahhh... i like driving with my crooked steering wheel! (yea somehow the steering is all screwed up, i really need an alignment now, just gotta find a respectable shop near by
i think im going to raise the clip up a notch, my flex pipe is 1" off the floor n i feel like im bound to break something. I believe there were 4 notches, which would u recommend to move it to that will keep the shocks safe?
If you measure the distance between the notches, multiply that by 1.5 and that's about how much ride height change each notch level will make.
ohhh you must have the SP3 versions, which should have 5 notches on all 4 corners. Regular Sports have 2 in front and 3 in back.
kk, thanks alot!
rm07
Nov 1, 2007 03:50 PM
