how to tell if timing belt is new?
Old Sep 24, 2002 | 08:49 AM
serious's Avatar
Default how to tell if timing belt is new?
i suspect that the timing belt in my engine was replaced very recently. is there any way to check?
Old Sep 24, 2002 | 08:56 AM
EP3_05's Avatar
Default Re: how to tell if timing belt is new? (serious)
Well inspect how it looks...does it look worn and falling apart at the edges or does it look crisp and fresh??
Old Sep 25, 2002 | 11:43 AM
virginia_dude's Avatar
Well an old belt can still look new. Think about it what is worth more, a $25 belt or your engine. You will likely bend a lot of valves if it breaks. Age is as much a factor as miles when you consider if its time to replace the belt. If you know neither, its best to replace it. THe head gasket alone cost twice that and if you bend a valve you are into a LOT more money than $25 and an hour or so of your time.
[Modified by virginia_dude, 3:46 PM 9/25/2002]
Old Sep 25, 2002 | 11:53 AM
memphiss13's Avatar
i have a brand new timing belt for a b16 sitting in my garage. if you want it you can have it for $30 shipped. just let me know
serious's Avatar
Default Re: how to tell if timing belt is new? (virginia_dude)
the thing is, i think the timing belt was just done on my new engine, probably less than 10,000 miles ago. it it was, i wouldn't want to take the time and money to do it all again.
thanks, but i have a z6.
[Modified by serious, 3:54 PM 9/25/2002]
Old Sep 25, 2002 | 11:56 AM
Max_ED9's Avatar
well then i guess if you knew for sure (a receipt or some proof) than you would be ok... but never take by word. i can say i changed my belt yesterday when in reality i never have (just an example)... so you choose the $25 or the new engine.
Old Sep 25, 2002 | 12:10 PM
serious's Avatar
Default Re: how to tell if timing belt is new? (maxracing)
fine, if it'll make you happy i'll change my timing belt.
joking dude, relax.
like you said, if you can't be sure, don't take the risk. by the way, if the engine sits for a long while (we're talking months) is it normal for the seals to leak a little oil?
todenbach
Jan 26, 2014 12:26 AM
65td
Jun 3, 2010 07:36 PM
omeara7
Jul 8, 2004 07:12 AM
zeke mccune
Apr 14, 2004 04:38 PM
expow
Sep 20, 2003 07:57 PM
