No crank, any ideas?
Old Jan 15, 2011 | 03:49 PM
soodominican's Avatar
Icon3 No crank, any ideas?
So I drove the car to school with no problem and when I went to start the car after I was done with class, it won't crank. Things I've done so far:
1)battery @ 13v
2)main relay works
3)fuel pump cycles
4)no fuses blown
5)12v applied @ both starter power wire from battery & black white signal wire
6)starter was tested @ Autozone, turns
I would like some ideas to try out on Monday when I return to school as I was forced to leave the car there friday
Thanks to all those who input
Old Jan 15, 2011 | 05:03 PM
FEAR6655's Avatar
Default Re: No crank, any ideas?
Does the starter solenoid actuate? Any noises at all from the engine?
Old Jan 15, 2011 | 05:06 PM
mitsubishiv5's Avatar
make sure you have correct ground at the engine. either correct ground at the transmission housing, and possible a correct ground at the valve cover.
Old Jan 15, 2011 | 06:31 PM
The solenoid does indeed actuate.
Grounds are good, I've been checking for power and grounds using my brother's Power Probe.
Thanks.
Old Jan 16, 2011 | 07:06 AM
Any other suggestions?
Old Jan 16, 2011 | 08:33 AM
Projekt_Ef9's Avatar
Did you check the ignition switch?
leigh-a
May 21, 2017 08:47 AM
frogg5872
Jun 23, 2010 10:45 AM
lsvtec2000
Mar 5, 2008 04:12 PM
Tippyman
15
Nov 13, 2007 08:55 PM
Leets
13
Mar 13, 2002 06:09 AM
