what kind of oil are you using?
i have a '94 EX with 146k on it. the book recommends i use 5w30, but i wanted to put in castrol GTX high mileage oil and it only comes in 10w30. is this ok? the book says only use 10w30 if your temperature never goes below 20 degrees F (-7C). should i not use 10w40? what oil do you use in your high mileage? i've heard bad things about synthetic.
I use normal GTX. works fine.
You could use the 10W-30 in the spring, summer, and fall. Then when the colder weather starts, use the 5W-30. I'm sure 10W-30 won't kill it but starting an engine in cold weather causes a lot of wear. The thicker winter viscosity oil will no flow as easily when it's cold and will take longer to properly lube your engine.
[Modified by Nitz5785, 12:58 PM 9/24/2002]
just dumbasses that cant afford mods period, i see it on other boards, its pathetic
Kind of like the ones who list what stickers they have...
_______
<FONT COLOR="#354463">~Chris
The Soy Bomb - '94 Accord EX Coupe</FONT>
<FONT COLOR="#5F7797">Stuff Added: Tokico Illuminas, Ground Controls, Pilot Strut Tower Brace, AEM CAI, 2.25" exhaust, high flow cat, Tenzo R muffler, </FONT><FONT COLOR="#ff0000">AEM Sticker, Mobil 1 10w30 synthetic oil</FONT>
<FONT COLOR="#7C8AA4">Stuff Removed: Backseat, ABS</FONT>
www.accordinglydone.com - Coming Soon!
[Modified by Martaigne, 2:17 PM 9/24/2002]
5w30 in the summer time gets torn up too easily
it would burn close to .5-1 whole quart in a normal week(depending on ambient temps)
that was in reference to mobil 1...........
Well, if that is the case, I don't know what to say. My car has only gone through two quarts of oil all summer with some hard driving.
I use Valvoline 10w30; 3.5 quarts regular, 1 quart synthetic. Barely any volitile burnoff compared to other oils myself (& friends) have used...good synthetics excluded...
Viola: Semi-synthetic and in a proportion that I know....not some vague variable like 'durablend'.
