CU2 VMR VB3 19x9.5 +45 all around 5x120 conversion to 5x114.3
VMR VB3 Hyper Black
19x9.5 front and rear!
+45
5x120 CNC milled to 5x114.3
centering rings
i love the color because it looks like black chrome
also concavity all around! mmmmmmmm
there's clearance with inner suspension and brake clearance.
well i did it! 19x9.5 all around fits well!
my car is still in under construction and dirty as hell. i took off my LS tips to be repositioned when i have my type s rear lip on.
so i bought two used 245/35/19 and mounted them on the rims
i put them both on the driver side front and rear. i did a test drive to see if there's any issue with suspension clearance and rubbing. no rubbing what so ever even though im dropped with Tein S Techs (1.6F / 1.4R).
im getting two used tires 235/35/19 in a few days and mounting those on the front this weekend, while the 245/35/19 will go on the rear. also installing hub centering rings next weekend.
car will look a lot better when i have my type s kit repainted and installed with these rims and a car wash
tires look too beefy with 35 series. what you guys think about 30 series?
also i think i need to be lower with some coilovers. we'll see
dslr pics
+45
centering rings
dslr pics
best investment ive made so far
just added hub centering rings to reduce/eliminate wheel vibration
$8 for a set of 4. its made of plastic. aluminum centering rings will cost about $25-$40 a set
72.6mm OD (outside diameter) x 64.1mm ID (inner diameter)
i did a test drive on the streets and highway and the vibration has been eliminated!
http://www.youtube.com/watch?v=5BGKG678mmQ
Papichulo1767
Honda Civic (2001 - 2005)
Jun 12, 2013 03:45 AM
defcon
Feb 23, 2011 08:08 AM
defcon
Jan 16, 2011 12:23 PM
gtturborex
Oct 1, 2005 06:13 PM
