Question and opinions needed for JDM front end...
Old Jan 15, 2011 | 01:11 PM
daitantamashii's Avatar
Default Question and opinions needed for JDM front end...
I'm thinking about purchasing a DC2 sometime soon. I've had a 2001 GS-R before and was going to go front-end on it, but I had to sell the car. And I'm thinking about continuing where I left off but with another car.
I'd like to know what most people do as far as buy the kit goes. I've done some research and do most people replace the whole radiator support for the JDM one? Or just modify the headlamp bar and swap the T supports?
Either way would work, but I want to know the advantages and disadvantages of each route, if possible...
Thank you very much!
Old Jan 15, 2011 | 05:00 PM
94 ls-r's Avatar
Default Re: Question and opinions needed for JDM front end...
I did the whole support. Had to cause old one was bent from minor wreck. Just make sure if you do the whole thing that it is properly welded on and set straight before welded. I believe if you just do the light bar it is easier to get straight. It wasnt really to bad to do. Just alot of drilling to get the spot welds out
Old Jan 16, 2011 | 12:14 AM
Hmm okay yeah I see. Definitely a lot of drilling, I've heard about that. Anyone else?
Old Jan 16, 2011 | 03:25 AM
xero_xero's Avatar
full sopport is the best way to go. it has all of your oem bolt ups, looks clean and takes about 8 hours. it also gives you time to touch up and paint anything you may need to to get the cleanest look possible.
Old Jan 16, 2011 | 12:12 PM
94 ls-r's Avatar
Oh and dont forget you have to get a da hood latch. The dc2 one is to short. Wiring isnt to bad. Ya have to hook up the front corner lights to run because in japan the corner lights dont light up.
Old Jan 16, 2011 | 02:53 PM
hbcrazy88's Avatar
i just used the uper t- support SOOOO MUCH EASIER. and you dont need another hood latch but you do need a DA cable for the latch.
Old Jan 16, 2011 | 05:28 PM
safedriver's Avatar
If you decide to replace the entire radiator support, you should go to a good auto paint store and buy a 'spot weld' drill bit. It will make the re-welding easier.
Old Jan 16, 2011 | 07:07 PM
94 ls-r's Avatar
I am pretty sure the cable and latch are the same
Old Jan 16, 2011 | 08:41 PM
Helpful feedback information so far!
Old Jan 16, 2011 | 11:51 PM
k20ateg's Avatar
the whole swap is easy, gotta use the radiator support and you gotta spot weld for a legit swap
Old Jan 18, 2011 | 12:03 PM
94 ls-r's Avatar
Oh and get the headlight plug that you wire up to plug into the headlight. Dont use spade conectors.
Old Jan 20, 2011 | 06:50 PM
Can you specify on this? I'm not too sure what you're talking about here...
Old Jan 21, 2011 | 06:03 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
If resale value and "doing things the right way" are things you care about, there's really only one answer here.
Old Jan 21, 2011 | 09:55 AM
94 ls-r's Avatar
The jdm headlights have one big connector that plugs into it to control head lights corner lights and turn signal. Most conversions dont come with this plug. You can use spade connectors and plug them in seperate or order the right plug and wire it up. I dont remember where I got em at
Old Jan 22, 2011 | 09:07 AM
Phat4Door's Avatar
Best bet is to go through Steve at Hmotorsonline.com. He sells you everything and if something isn't right or severely damaged when it gets there he will fix it immediately. My buddy's ITR front came with an HID that wasn't working, it would just flicjer with power then shut off, we called Steve, had a new working one in 3 days, he would have gotten it there faster but her didn't have to have it so he told Steve he didn't have to over night it. I bought all my parts new other than the head lights but if I had it to do over again I would have gone through Steve! SO much less aggravation.
Old Jan 23, 2011 | 06:32 PM
JDMDC2 88's Avatar
dont hack it up, put a new rad support in
Old Jan 23, 2011 | 08:36 PM
1998GsRIntegra's Avatar
If your going to go jdm front, dont hack up a good integra with a good usdm front end. Buy one that doesnt look so great on the cheap. You will have to paint it after you do the front end any way. Might as well save some money on the project. Just my opinion.
Old Jan 23, 2011 | 11:21 PM
Blah.'s Avatar
u can use eg hood latch too
Old Jan 24, 2011 | 04:05 PM
94 ls-r's Avatar
Its the da cable that is needed. I got the whole thng cause mine was bent
Old Jan 24, 2011 | 04:17 PM
UpNextCarParts's Avatar
Do it once, do it right.
Old Jan 24, 2011 | 08:53 PM
53JDMDC2's Avatar
i did mine 2 times. the first was the whole core support the second was from the shock towers forward. that eliminated the airbox hole in the fender apron.
all accident related b.s.
smoked08
Apr 4, 2011 09:48 AM
phivrne
Welding / Fabrication
Aug 3, 2010 09:32 PM
tempname
Jan 30, 2008 07:12 PM
LightningSpeed
Dec 16, 2005 10:25 PM
J_SpeC_EK
Mar 29, 2005 12:01 AM
