B20 questions?
Old Jan 15, 2011 | 10:59 AM
zeusdavis's Avatar
Default B20 questions?
I am buying a b20b from hmotorsonline. I want to know which motor i should get there is a big price difference cause of specs here is specs and price...
126Hp 131Trq 8.8 Compression(96-98)
146Hp 133Trq 9.6 Compression (99-00)
$ 575.00 Plus shipping and handling 96-98 Spec
$ 750.00 Plus shipping and handling 99-00 Spec
I want to know which one i should get because regardless of which b20 motor i get i am putting a b16 head on it. Any opinions?
Old Jan 15, 2011 | 11:13 AM
alex14's Avatar
Default Re: B20 questions?
I think most of the power in the newer B20's comes from the higher compression and head, so if you are going to put a B16 head on it anyway, I would get the 96-98.
Old Jan 15, 2011 | 11:18 AM
.Manny.'s Avatar
Touching My Member
What are your plans for it?
Old Jan 15, 2011 | 11:32 AM
zeusdavis's Avatar
Well my b18 blew up so im swapping it with a b20 (obvious) well I am going to put on a b16 head to make B20/vtec I would like to be able to make 200 horsepower Eventually, Not as soon as i get it, But i was thinking b20/vtec with cold air intake, b18 header, a new feul injectors, then maybe a tune to start. But i know horsepower is an addiction so im sure my mind will be changing alot after i get this motor to were i feel i want it
Old Jan 15, 2011 | 03:40 PM
zeusdavis's Avatar
Can Anyone verify this?
Old Jan 15, 2011 | 03:46 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
power is from the bump in compression and the ecu that runs it. the head is the same. the best head is the 97 p8r head that came on some b20bs. if your doing a b20v its up to you but the phk pistons are way better for all motor then the b20b pistons. or you could use the saved money and put that towards rs machine pistons and arp rod bolts.
Old Jan 15, 2011 | 04:36 PM
zeusdavis's Avatar
Well Money isnt the problem if i should get the 146Hp one im going to i get payed 400 a week and i dont spend money on anything else. And tax returns are right around the corner
Shaunathan
31
Feb 4, 2012 10:57 AM
zeusdavis
17
Feb 12, 2011 10:57 AM
Jurassic Four
Jun 25, 2004 06:58 AM
d16y8EL
Feb 6, 2004 09:43 PM
Ray
Nov 15, 2001 06:36 AM
