Overheating when parked
Old Jan 15, 2011 | 04:21 AM
LLkoolskillet's Avatar
Default Overheating when parked
This is very strange to me.... Last night i was sitting in my car which is a 99 accord 4dr 2.3L. The temp gauge was reading like the car was overheating. Then when i started driving the temp went back to normal. It seemed it only did this when the car was running while it was parked. What could this mean? The Thermostat is going bad or is it the water pump? The car has just reach 100K so i know that its going to need the 100k tune up. Ive owned 4 hondas and have never seen any of them do this until now. Any Ideas???
Old Jan 15, 2011 | 04:57 AM
lazlong's Avatar
Default Re: Overheating when parked
Is the coolant fan coming on when your sitting there overheating? If it isn't it's either the fan motor, the relay, or the ECT sensor.
Old Jan 15, 2011 | 07:24 AM
accord99power's Avatar
agreed check fans for sure.
Old Jan 15, 2011 | 07:37 AM
Will do...... thank you
Old Jan 15, 2011 | 07:46 AM
If I remember correctly the fan should come on momentarily after the car has been idling. Im talking maybe 3-5 min after sitting, right? Also the ECT would throw a check light if it was bad, cause i have no light. Ill start small, listen for motor to turn on first then move to relay then sensor.
Old Jan 16, 2011 | 10:40 AM
lazlong's Avatar
To check the fan motor: Disconnect the connector. Apply battery positive to one terminal and ground to the other. As soon as you connect the second wire the fan should come on if it's working. * Doesn't matter which way the wires are connected as the fan will just spin the other way.
tyler's car
May 26, 2014 07:12 PM
JoeCereghino
17
Nov 30, 2008 08:41 PM
petersayarath
Jun 16, 2005 04:59 PM
ismokev8s
Dec 9, 2004 01:33 PM
spart
Feb 27, 2002 04:07 PM
