91 civic si noisy clutch release bearing
Old Jan 14, 2011 | 08:06 PM
hatchet_honda's Avatar
Default 91 civic si noisy clutch release bearing
i have a 91 civic si with a d15b and an si cable trans. i swapped this motor in last feb (almost a year ago) and installed a new exedy clutch kit as well. ive noticed within the past few days that i have quite a noise when the clutch is released, kinda squeals when i take off in first gear. theres also a sort of whining noise when i release the pedal (isnt a noisy pedal arm) and it goes away when the clutch is pressed. could this be the input shaft bearing and not the release bearing? i can change a throwout bearing without much problem but cracking into the trans casing is another story
Old Jan 14, 2011 | 10:01 PM
.Manny.'s Avatar
Touching My Member
Default Re: 91 civic si noisy clutch release bearing
That's your input shaft bearing man. I know, it sucks, but it's common on these transmissions.
Old Jan 15, 2011 | 01:24 PM
how long do you think i have before the trans effs up internally?
Old Jan 15, 2011 | 01:34 PM
BiG ChOr!Zo's Avatar
^ive been driving mine with a noisy isb for 9+ months straight now and it still drives like a champ...then again i don't drive like an idiot and i have yet to hit redline with my new motor
Old Jan 16, 2011 | 11:23 PM
yeah im not driving this si all nutty either. its my daily that i drive to work and such. it shifts and drives fine so far just that noise when driving or idling.
Old Jan 17, 2011 | 12:27 AM
.Manny.'s Avatar
Touching My Member
Some take forever and some go rather quickly. Eventually the bearing will fall apart and could potentially eff **** up.
Old Jan 17, 2011 | 03:53 AM
andyz's Avatar
What about the throwout bearing. What is the danger of that failing?
Old Jan 17, 2011 | 09:05 AM
.Manny.'s Avatar
Touching My Member
It will probably chew up the pressure plate since it will no longer spin with it.
Old Jan 17, 2011 | 03:56 PM
got my dx hatch done with its swapped b7. had to pull the b16 i juss put in over the summer cause i wasnt passing emissions with that motor. so looks like i have the dx to drive while i pull this si trans out. def not gonna drive my car very far until its fixed
soung87
Transmission & Drivetrain
Nov 19, 2013 06:10 PM
dwils
Mar 5, 2011 12:24 PM
clewis3
Mar 22, 2010 03:37 AM
red_rex_89
10
May 6, 2007 07:13 AM
pa2play
Jul 28, 2005 09:42 AM
