problem on old full-race.com car that has never happened before HELP
recently i bought the old full-race.com coupe and got it retuned by charm city tuning and everything was good for a week but now it wont stay running.
problems:
wont stay running
mil will flash really fast at 1700rpm
s300 wont pick up the mil
car loads up and starts to backfire
everything was fine. i did a full pass and drove home and parked it then next day it started running funny.
i had some harness problems when i got it and a tps problem but thought i fixed it and a few people seem to think its the harness is grounding out or the engine grounds or even the tps again but it was reading when i logged it
help please.
problems:
wont stay running
help please.
James, when did this thing make 649 on low boost? At CCT?
And Rick,
I have a question for you about some work if interested. I had the black h2b hatch at MIR, i was talking to Taylor and saw you there. I need some tranny input, and maybe some one to build it. Transmissions scare me, and i was wondering if you build them. Thanks man
Sounds Interesting ^^
And Rick,
And Rick,
Have u covered the basics yet?
all engine grounds.
Main relay.
Fuel pump setup.
Swapped to another ecu, or burn a chip on older software & see how it runs?
all engine grounds.
Main relay.
Fuel pump setup.
Also double check in your software that your settings are still correct for the calibration, map sensor, fuel, ign settings etc.
Yeah, there's a good idea...
Let's throw the trouble free management system in the garbage and open up a new can of worms with an AEM unit...
:facepalm
As Chad stated, either the ICM maybe going bad or the wiring going to it >>
:facepalm
try reloading the map in it we have had a few problems with the latest s300 software,but not as many as the pos aem
