LSD in GSR Help
Old Jan 14, 2011 | 02:07 PM
JDM Jeff 95civ's Avatar
Default LSD in GSR Help
So im attempting to put an LSD in my 98 GSR. I was wondering if i could get some advice on the procedure. More specifically on getting the specs right and how to check if its right because as ive heard so far its not just a throw it in and go type situation. Thanks for any help.
Old Jan 14, 2011 | 02:55 PM
Mr. EG's Avatar
Default Re: LSD in GSR Help
Yes you may have to start shimming and adding washers. I suggest you leave it up to a pro if you are scared and do not want to mess anything up.
Old Jan 14, 2011 | 03:11 PM
Well id like to know for the experience seeing as im an interning honda tech. This is just something ive never done before because a customer has never requested ya know? All data doesnt say much and theres no manual or anything. i can do it if i had some kind of instructions.
Old Jan 14, 2011 | 03:35 PM
racebum's Avatar
videos are on youtube of just this
Old Jan 14, 2011 | 04:40 PM
Mr. EG's Avatar
All data gives you more than enough information, trust me.
Old Jan 14, 2011 | 06:04 PM
1998GsRIntegra's Avatar
There are great youtube videos as sideways said. Evans tuning did a couple videos on the process. I think they made 2 videos. The first being disassembley and the second being re-assembley. Both very well done.
Old Jan 15, 2011 | 01:19 PM
BrownDx's Avatar
I followed this to do mine.
One thing I didn't do at first was switch to type r bearings, make sure to do that and save yourself the money. Good luck.
http://www.xm-parts.com/articles/hgear/gear.htm
Old Jan 17, 2011 | 09:06 AM
wow thanks everyone! Do you mind me asking why to switch to type R bearings? will they blow out? or just wear faster?
Old Jan 17, 2011 | 10:57 AM
BrownDx's Avatar
It has to do with the gsr bearings being measured with preload rather than clearance, nothing with the performance or wear of the bearings.
Old Jan 18, 2011 | 04:11 PM
So i tried to measure the preload and it is out of spec. Its way to loose. So your saying if i used the GSR Diff bearing my preload would have been closer to spec?
Old Jan 18, 2011 | 04:48 PM
BrownDx's Avatar
The only reason I suggested switching the bearings is for the ease of measuring the clearance between the diff and the case. I didn't have a tool to measure preload.
If it is out of spec you should need to order a different shim from Acura to put it in spec.
Old Jan 19, 2011 | 03:17 PM
Yea i figured. What a bummer. With that tool this would be so easy. without it its annoying trying to measure with homemade tools.
Old Jan 19, 2011 | 09:14 PM
BrownDx's Avatar
Yeah, I started to make a tool and then found that article and did it the other way.
Old Jan 25, 2011 | 09:42 AM
I finally got it in and used an inch pounds dial torque wrench and set the preload to 19 inch pounds. Another tech told me that was too tight for a used bearing. What do you guys think? My source said 18.6-22.4 Inch pounds but didnt specify if that was for a used or new bearing
Old Jan 25, 2011 | 01:06 PM
igorka_91's Avatar
Why not use the b16/ls diff bearings...? No preloads and all u have to get is a properly sized shim from the stealership wich is um 14$. This is what i followed when i put in a lsd into my gsr trans.....http://www.xm-parts.com/articles/hgear/gear.htm just like brown dx posted. Follow how he does it. Its simple. Dont be scared to try it. I did it..took my time and i have an lsd gsr with ls 5th gear trans in my car.
91_si_b16
Transmission & Drivetrain
Feb 7, 2016 10:55 PM
bluenc-87
May 2, 2010 02:50 PM
typhoondriven
Jun 8, 2008 04:18 AM
powerofdreams
Aug 18, 2005 08:06 PM
patdemps
Jul 24, 2003 04:02 PM
