Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2003 Odyssey Interior Removal? (cup holder)
Old Jan 14, 2011 | 12:47 PM
D16Z6racing's Avatar
Icon2 2003 Odyssey Interior Removal? (cup holder)
Driver side, third row, cup holder/storage area next to the rear speaker. How the does it come out? I've scratched the interior panels a bit more than I would have liked to trying to just pop it out.
My kids seem to have a science experiment inside it, so I need to remove it for cleaning.
Old Jan 18, 2011 | 08:05 AM
NDNV's Avatar
Default Re: 2003 Odyssey Interior Removal? (cup holder)
Trim Removal/Installation - Rear Side Lower Area
NOTE:
• Put on gloves to protect your hands.
• When prying with a flat-tip screwdriver, wrap it with protective tape to prevent damage.
• Take care not to bend or scratch the trim and panels.
1. Remove the trim as shown.
• To remove the rear side trim panel, remove the speaker grille and rear speaker.
• When removing the side trim panels, be sure to remove the mounting screws behind the rear speakers.
• Be sure to disconnect the rear accessory socket and brake light failure sensor connectors when removing the left rear trim panel.
2. Install the trim in the reverse order of removal, and note these items:
• Replace any damaged clips.
• Push the clips into place securely.
• Apply liquid thread lock to the anchor bolts before reinstallation.
• Before installing the anchor bolts, make sure there are no twists or kinks in the seat belts.
Remove the SECOND ROW SEAT BELT LOWER ANCHOR BOLT, THIRD ROW SEAT STRIKER COVER and THIRD ROW SEAT BELT LOWER ANCHOR BOLT. There are 8 clips on the driver's side panel.
I haven't personally done this but this is what the manual says to do.
taken roads
Honda Civic (2001 - 2005)
May 2, 2006 10:00 AM
in-n-outboy
Jan 26, 2006 05:58 PM
dsmIA
Aug 9, 2005 10:33 AM
hitop
Apr 24, 2003 12:46 AM
T_Rex
12
Jan 30, 2003 07:27 AM
