short gear or long gear for boots?
Old Jan 14, 2011 | 12:21 PM
wtsapexipowerfc's Avatar
Default short gear or long gear for boots?
currently I have a vitara build d16z6 T3 50 trim.
I currently have a S20 long gear transmission.
Would i benefit from going to a shorter gear Si tranny?
I think my rear main seal on my transmission in currently going and thus causing motor oil levels to decrease gradually.
Old Jan 14, 2011 | 12:33 PM
SovXietday's Avatar
Default Re: short gear or long gear for boots?
The only time longer gears are better is when your gearing is too short to reach a max speed in a certain distance. IE, if you're topping 4th before the line.
Other than that, you will ALWAYS benefit by going with the shorter choice of gearing.
Old Jan 14, 2011 | 12:56 PM
Mr. EG's Avatar
In your case you will benefit from the Si trans.
Old Jan 14, 2011 | 12:59 PM
ok
so for 255whp and 208lb ft torque an Si tranny will do fine?
can i get an EK tranny? which code will an EK SI tranny have?
Old Jan 14, 2011 | 01:07 PM
Mr. EG's Avatar
A D16z6 ex/si trans has the same gearing as the D16y8 ex trans. I believe the general code is S20, but do not remember how to distinquish between a CX,DX, ETC. I rebuilt a CX transmission and the code on it was S20 also.
Old Jan 14, 2011 | 01:38 PM
To ID : Look by the fill plug. You'll see a circle cast into the housing.
P20-A000 = DX,CX,VX trannys
P20-B000 = Si,EX trannys.
Old Jan 14, 2011 | 05:30 PM
Mr. EG's Avatar
There ya go.
Old Mar 7, 2011 | 06:49 PM
Right now I have a long geared DX or VX not sure which exactly.
Will the SI make the car feel much quicker?
I am a d16z6 boosted setup.
also, I have an option to take the shift linkage with the transmission I am going to buy. Should I replace my old shift linkage with the 1998 one?
Also, would this incur a lot more labor when swapping out my current transmission with the Si tranny to have the shift linkage changed as well?
Old Mar 7, 2011 | 10:39 PM
sc34dc4's Avatar
You have to disconnect the shift linkage from the tranny anyways when you swap it out but if your bushings are fine then you don't need to switch it. It's only 3 more bolts though if you're dead set on it.
4g4dcruisin
May 11, 2010 08:18 AM
Frederick_Est87
Jul 3, 2009 11:56 AM
nihad
Nov 8, 2007 09:59 PM
typemismatch
10
Feb 8, 2006 08:15 PM
senpai
10
Oct 14, 2002 01:24 PM
