Transmission & Drivetrain Gearboxes, Differentials, Clutches
D series transmission
Old Jan 14, 2011 | 11:31 AM
wtsapexipowerfc's Avatar
Default D series transmission
my current car is 92 to 95 eg civic
d16z6 engine
Vitara with a T3 50 trim turbo
currently has a s20 transmission (long gear)
What is the latest model civic transmission i could use? civic ek ?
Would there be any benefit of using a shorter geared transmission from an Si?
If my rear main seal is in fact leaking, will this cause engine oil consumption? Is the transmission rear main seal expensive seal to replace? or is this replaced with the addition of a new transmission.?
Old Jan 14, 2011 | 12:37 PM
m_shake's Avatar
Default Re: D series transmission
ek is the newest tranny that will fit. A leaking rear main won't cause it to consume oil, but probably leak out.
And i don't have experience w/ a turbo honda so i can't recommend a shorter geared tranny, all i know is all except jdm dohc zc tranny suck compared to b series, as far as ratios go that is. But that's nothing a little gear swapping won't fix
Old Jan 16, 2011 | 04:39 PM
sneeb's Avatar
what s20 do you have
Old Jan 16, 2011 | 05:18 PM
EGRhatch's Avatar
/Thread
Old Jan 17, 2011 | 11:33 AM
arronabraham's Avatar
Icon6 Re: D series transmission
i have i 96 hatch with the non vtech d16y7 i was wondering if i could bolt a gsr tranny to it will i run into any problems/ is it even possible
Old Jan 19, 2011 | 09:09 AM
94EG8's Avatar
Seagull Management
No, does not bolt up. You can use a D-series EX/Si tranny from a '92 - '00 Civic
OP Run a D-series EX/Si tranny, get an LSD if you can afford one at all (and no OBX doesn't count)
Old Jan 24, 2011 | 12:19 AM
sneeb's Avatar
Originally Posted by EGRhatch
I just got a headache trying to read that poorly written article
WillSB
May 4, 2009 08:25 PM
Hill4589
Mar 26, 2009 06:49 PM
blaze the chemi
11
Sep 18, 2008 05:28 PM
grog
Apr 25, 2008 03:24 AM
spoonek4
Feb 13, 2002 03:03 AM
