89 ef si ls/vtec fs/ft??
hey whats up i have a ls/vtec ef
built bottom end
1st gen b16 head
gsr cams
bottom has 6k built it last december
270 compression all 4 cylinders! (done in 06/2010)lower now due to oem head gasket
81.5 ml forged srp pistons and forged eagle rods
acl bearings
arp head studs
new piston rings
stage 2 clutch
new oil/water pump
tri-y 2.5 in headers full apexi exhaust with ws2 apexi muffler
kyb struts all around with coilovers
front real jdm vision camber and rear blox camber
battery in trunk
b16 cable trans
obd1 gsr dizzy
phearable reburnable ecu
vtec hits @ 5200
redline@ 9000
check engine shift light @ 8600
hasport motor mounts
14 in. steelies with 95% tred
blox lower control arms (red)
13" steering wheel with red h horn
sunroof
rear disc conversion
new nrg trail arm bushings
94 integra front knuckles
hasport shift linkage
s2 short shifter
gsr shift ****
fuel pressure regulator
crx front lip
si interior
all 4 mud flaps (that say honda)
inspected til december 2011
pulls very hard
nice set up
theres alot just cant remember right now
3500$ obo...
possible add ons...
-s2st2 cams-tuners
-440 injectors
white 99 si's needs tires
original red si 89 text me @267-475-1874
new oem head gasket
new oem lma's
new type r valvetrain
new super-tech valve seals
new v-tec soli gasket
new golden eagle cam cap
new oem cam seals
new oil pan gasket
new injector seals
all done 8-7-11
built bottom end
1st gen b16 head
gsr cams
acl bearings
arp head studs
new piston rings
stage 2 clutch
new oil/water pump
battery in trunk
b16 cable trans
obd1 gsr dizzy
vtec hits @ 5200
redline@ 9000
sunroof
s2 short shifter
gsr shift ****
crx front lip
si interior
pulls very hard
nice set up
3500$ obo...
possible add ons...
-s2st2 cams-tuners
-440 injectors
new oem head gasket
new oem lma's
new oem cam seals
new oil pan gasket
new injector seals
all done 8-7-11
Bump. I built the motor and did every upgrade very solid car built right fun car to drive and a deal for 3500 I spent a lot of time working on this car trust me good luck on the sale D! I still don't want to see it go to many memories
haha
haha
