Knock Sensor Location LS-V
I picked up an LS-vtec to replace my GSR
And i feel really stupid asking this, but i cant find the knock sensor!!
I know the B1 didnt come with one, but i would think they would have put one on because this motor cam out of a running car, with no CEL's.
Any info would be awesome!!
Thanks
Thanks
So i found a guy to chip my ecu, and to burn me a chip.
When he opened it up he found that my ECU had been tampered with before and the board was burned.
He is going to try and repair it.
We will see what happens.
Anything special you should look for/do when not running a knock?
Depends on how stout you've built your bottom end. If you rev too high and it starts knockin it won't retard timing and it'll be easier to blow it. Just don't beat on it recklessly and keep a ear out for wrapping/knocking in the engine
Best way to hear it is give it a slight rev to around 3k and listen for it as it drops rpms. Being semi-new to engine internal work, I find myself constantly checking for it just in case it does I can tear it apart and throw in new bearings without scorring the crank
Hmm...
well i didnt put this ls-v together.
I bought it of craigslist.
But i picked it up from the guys house, so if i have any issues i will come back and f#$*k Him up.
soo, what is safe operating rpms? is 91 Octane enough for an all stock internals B1 bottom end with GSR head?
Most people would say 8k...ish depends on the person.
I've had idiots say they rev their ls's to 9k no problem but there ain't no power up there anyway
I usually keep my ls bottom ends under stock rev limit think its 7.8k??
Id look into arp rodbolts and a block girdle so you can at least rev it up to 8.5 and see the high end power from the vtec head
And you should be ok on 91 with a good tune
Will the gsr block girdle drop into the ls block? What do I need to replace at the same time? I have a girdle on the shelf so im thinkin about doing that!
whether the brace provides any useful advantage for a moderate street build is also debatable.
false. you can use the gsr brace if you're willing to modify either the brace or main caps. the crank in use does not come in to play for something like this. plenty of info available on this topic; search function is your buddy.
How much am i going to gain from installing the girdle?
200rpm? 400rpm?
The motor is all together right now.
and hopefully going in this weekend.
But we will see.
I dont have the time to pull it apart to replace it with ARP Rod studs.
But yes, i realize it is the safest option.
I will just burn a chip for the safest rpm.
So you guys think that 8,200 is a safe Redline for LSvtec? 8,000?
But we will see.
