CRX D16A6 crank but won't start.
Old Jan 13, 2011 | 09:48 AM
kaiba's Avatar
Default CRX D16A6 crank but won't start.
Help a friend out. Car will crank but won't start.
CRX D16A6 all stock in a CRX Si 90
Fuel pump works with 1/2 tank of gas
Car getting spark
Timing is top dead center
No CEL
Replaced spark plugs
Compression
1: 180
2: 80
3: 120
4: 60
Still won't start. Any other tips?
Old Jan 13, 2011 | 12:15 PM
HaulingAddison's Avatar
Default Re: CRX D16A6 crank but won't start.
pour a little oil down the spark plug holes. If the compression goes up and the compression numbers are closer to being the same on all cylinders, your rings could be going out. If it doesn't change by much or at all, it's more likely your top end. Either way, with compression numbers like that you'll probably need to look into rebuilding your engine or a head gasket.
Old Jan 13, 2011 | 12:45 PM
uncl3j0n's Avatar
Are you sure your getting fuel to the cylinders? Might wanna check the line or see if the plugs smell like gas. Im currently having a similar problem.
Old Jan 13, 2011 | 02:03 PM
Jockone's Avatar
You need fuel/air mixture spark and compression for the engine to run.It looks like your problem is compression.
Old Jan 13, 2011 | 02:38 PM
meloylo's Avatar
this
that engine is no good and won't start with such low compression
time for rebuild
Old Jan 14, 2011 | 02:16 PM
buckner2009's Avatar
ya ether u got junk rings or bent valve' like he said ' poor little in cylinfers try comp again dont bump them up time for a 1.7 stroker
keep it going
Dec 7, 2016 11:10 PM
Patman
Honda Motorcycles
Jul 25, 2008 08:44 AM
hmtcrxsir
Jul 10, 2007 10:06 AM
Bngo731
Jun 5, 2006 02:42 PM
Goldfingiz
Aug 24, 2003 05:53 PM
