Texas -OK -LA (Sales) Texas, Oklahoma, Louisiana
FS: Ksport Kontrol Pro Coilovers Honda Civic 06-up CHD19-KP
Old Jan 13, 2011 | 07:19 AM
CleanBlk90si's Avatar
Icon5 FS: Ksport Kontrol Pro Coilovers Honda Civic 06-up CHD19-KP
UP FOR SALE IS A COMPLETE SET OF NEW Ksport Kontrol Pro Coilovers
For A Honda Civic 06-up
MODEL NUMBER: CHD19-KP
Retail PRICE: US$900 AND UP!!!
MUST SELL FOR 600 OR BEST OFFER
BOUGHT NEW, OPENED BUT NEVER INSTALLED (NEW) - ORIGINAL BOX AND ALL INSTRUCTIONS AND PACKAGING COMES WITH THEM
NO LONGER HAVE THE CAR SO I DON'T NEED THEM ANYMORE.
HERE IS WEB SITE INFO:
Looking to upgrade your suspension for your Honda Civic 06-up CHD19-KP .the answer is here with a set of Ksport Coilovers will allow your Honda Civic 06-up CHD19-KP to handle better and increase stability around corners and turns. We offer the lowest price on these Ksport coilovers for your Honda Civic 06-up CHD19-KP .
Spring Rate and Mount Front 7/392 Rear 9/504 Front P/U Rear OEM
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
Key Features:
* 36-way adjustable dampening
* Made from high quality 6061 Aluminum with T6 for increased hardness
* Compression/Rebound adjustable
* Adjustable spring perch for height adjustment
* Adjustable body allowing maximum suspension travel
* Pillow Ball Top Mount w/ adjustable camber (not available for some models)
* Monotube High Pressure Design reduces oil leakage
* Electroplated body for protection from corrosion and rust
* One Year Limited Warranty
SKU CHD19-KP
Weight 52.00 lbs
Pablo1997
Suspension & Brakes
Jul 8, 2016 10:10 AM
jasmin92993
12
Oct 24, 2013 02:00 PM
kakis2000
Feb 4, 2012 03:54 AM
rock2447
Suspension & Brakes
May 3, 2005 08:04 PM
chocobo15_2000
Apr 3, 2005 08:43 PM
