Adjusting boost on a Greddy TD05H-18G
Old Sep 24, 2002 | 06:25 AM
91CivicSi's Avatar
Default Adjusting boost on a Greddy TD05H-18G
So I've got the turbo from the Greddy GSR kit to go on my car in a few weeks. I was told that the previous owner set the boost to 10psi rather than the 7.8 that Greddy sets it to. How do I go about turning it back down to around 7psi? Do I turn the bolt on the wastegate actuator arm?
Also, most turbos that I've seen with internal wastegates connect the vacuum line off the wastegate actuator to a barb on the compressor outlet. My turbo doesn't have said fitting on the compressor. Where do I connect the vacuum line? Any source off the intake manifold?
Thanks.
Old Sep 24, 2002 | 06:36 AM
TheIntegraGuy's Avatar
Default Re: Adjusting boost on a Greddy TD05H-18G (91CivicSi)
For the actuator, find a vac source on the intake mani.
as for the boost, maybe the previous owner had a boost controller, or he did some funky actuator fancy smancy work....Ask him HOW he got it to boost 10, and then you'll know from there.
Old Sep 24, 2002 | 07:31 AM
RGAZ's Avatar
New User
To reduce the boost you want to lengthen the actuator arm. If you have a bolt on the arm, you want to turn it so the arm gets longer.
See my other post on where you get the boost source.
Randy
br1ev8
Apr 6, 2006 02:44 PM
DMax013
Apr 25, 2005 11:05 AM
maddog20
Aug 4, 2003 03:07 AM
TurboLude00
Oct 25, 2002 10:10 AM
