1949cc 260 whp KingMotorsports
Old Jan 12, 2011 | 06:07 AM
BearsEK-KMSU's Avatar
Default 1949cc 260 whp KingMotorsports
I figured I would make a thread specifically for this engine. Here was the thread that originated it. https://honda-tech.com/forums/all-motor-naturally-aspirated-44/kingmotorsports-modded-performer-x-thread-2873074/
1949CC (83.5x89)
13.8:1 compression
VP MS109
S2 Pro 3's
62mm Type R throttle body
KingMotorsports PX mod V2
Toda header
KingMotorsports Ultra build with hand ported head
Old Jan 12, 2011 | 06:37 AM
ghost914's Avatar
Default Re: 1949cc 260 whp KingMotorsports
nice numbers props
Old Jan 12, 2011 | 07:34 AM
92TypeR's Avatar
FSAE
On a TODA header and 62mm TB - Very impressive!
Old Jan 12, 2011 | 07:46 AM
eDm cRxXx's Avatar
^^what he said, very impressive!
I'm building a similar sized engine my self. Will be done in a month or two.
1980cc (85*87.2), 13.5:1 CR, jenvey ITBs, pr3 head with type-r valves (ported locally), custom bisi header, but only Pro 2 cams (just went with what we had from last season). Will run on E85 from the local gas station, or a mix of E85 and regular pump gasoline.
Hoping for 240+whp.
Old Jan 12, 2011 | 08:16 AM
092eg6's Avatar
was this through the muffler or open header
Old Jan 12, 2011 | 08:26 AM
2.5" exhaust back to the rear control arm. This is how the car will be run in competition.
Old Jan 12, 2011 | 08:27 AM
Like I said before this header is better than most people think...
Old Jan 12, 2011 | 09:05 AM
xbigpitax's Avatar
alot of the power is from the tune that line looks really good. i see p/s u got a.c also if so baller lol
Old Jan 12, 2011 | 09:26 AM
Dave99rt's Avatar
peak piston speeds getting to high to rev anymore?
it's kind of scary that power is still going up.
awesome tq curve!
Old Jan 12, 2011 | 09:36 AM
awesome tq curve!
No that isn't a problem, but it is a new engine no reason to rev it much more yet.
This car is just a test chassis. Engine is being shipped over seas. Power steering and AC are not hooked up.
Old Jan 12, 2011 | 10:29 AM
acura_b18c1's Avatar
sorry to get slightly off topic ... have u ever tested the power loss of PS and AC being hooked up by any chance ?
i read that u can keep the AC belt on ( have the system off ) and just take off the power steering belt for minimal gains .. any truth in this ?
Old Jan 12, 2011 | 10:45 AM
94-01 integra and 92-00 civic usually gain 3-4 whp without the PS belt. DA's usually make a few more.
Old Jan 12, 2011 | 10:52 AM
jr_deleon's Avatar
Very impressive, to say the least.
Old Jan 12, 2011 | 11:17 AM
OMG THE GOGGLES's Avatar
I think that the best part, is that the motor itself is not "overdone" look wise. It is purely purpose built.
Old Jan 12, 2011 | 01:34 PM
4g hatch's Avatar
any reason for not using a 68mm tb...is the type r better??
Old Jan 12, 2011 | 01:45 PM
98ITR_CIV's Avatar
You guys don't waste any time switching motors in and out of the test car. I can tell that the higher compression makes a big difference, nice graph!
Was there a difference, that you could tell, between v1 and v2 of the modified px?
Paul
Old Jan 12, 2011 | 01:50 PM
NAH2B's Avatar
good build, props on the results
we did a very similar build w/ the differences being 83.0mm bore, little less compression for pump gas and different intake and exhaust manifolds w/ 70mm tb. power and tq were nearly identical.
alot of people overlook the little b series engines but they can make great power if you know what your doing
Old Jan 12, 2011 | 11:02 PM
egb18c5's Avatar
you guys are always producing good numbers for a n/a B
Old Jan 13, 2011 | 02:01 AM
Kanagias's Avatar
Very impressive and simple set-up!!
I just want to ask what injectors are you using? and if would be a big difference in numbers if you were using 93 US pump gas (about the same with European 100 octane gas) instead of race fuel?
I can see that you using stock fuel rail and FPR.
I have a similar set-up (building in process) with 13.5:1+ C/R, PRO 2, 84.5*87.2 (1956cc), Toda header and 62mm T/B with Skunk2 V1 manifold.....I hope for 230-240 whp
I have from my old 1.8 set-up, AEM fuel rail, RC 320 P&H injectors and everythink else stock (OBD 0 ECU..is a CRX) and my tunner told me that will be fine with my new B19 set-up!!!???
Old Jan 13, 2011 | 05:18 AM
Yes. Class rules say the plate needs to stay 62mm but can be modified before and after. This throttle body is a spoon throttle body, (Thanks Paul). We did put a 68mm throttle body on it and it wasn't worth anything on the dyno but it felt better.
Paul
I really don't think there is a difference between the two or enough to make a difference. The runners are the same length. The plenum may be a hair bigger. It is just easier to make so it can be sold at a reasonable price.
Old Jan 13, 2011 | 09:59 AM
98ITR_CIV's Avatar
I am happy to see it go to good use. I should be thanking you for all of the work and testing you guys do and then sharing it with the community. Thanks!
Yeah, I am sure the awesome tuning makes a bigger difference than the difference between the two versions of the px. It sure seems like there is a bit of work involved either way.
Old Jan 13, 2011 | 06:22 PM
tempsohc's Avatar
Just to fulfill my itch to test the victor x myself. Would you show me some charts of a modded Vx vs Unmodded? also pics would be great. I was wondering what type of gains could be had by modifying the Vx (cut open and ported) would i sacrifice alot more bottome in to gain slightly higher hp?
Old Jan 13, 2011 | 06:41 PM
m_shake's Avatar
Very nice!!!!!! Thanks for sharing!
Old Jan 14, 2011 | 02:40 AM
d16z6Tcrx's Avatar
very nice
Old Jan 14, 2011 | 09:27 PM
jv88_dc2's Avatar
Any clue as to what the price is for a modded performerX?
I'm building a 2.1L 12.5:1 compression B and was wondering if this would suit me better or a ported victorX
