Cylinder Head
Old Sep 24, 2002 | 05:45 AM
whagkangmakulet's Avatar
Default Cylinder Head
can I use other cylinder head between 88-91 civic/ CRX? I'm planning to change my head gasket and I want to go to the junkyard and pull a cylinder head to have it rebuilt. i have an stock Si engine.
Old Sep 24, 2002 | 06:00 AM
EP3_05's Avatar
Default Re: Cylinder Head (whagkangmakulet)
If it is Si to Si yeah it will work fine.
Old Sep 24, 2002 | 06:41 AM
Louie B.'s Avatar
I've heard that all of the 88-91 d series heads are exactly the same except for the cam and valve springs. Any head will definately fit, but someone please confirm the fact of them being the same.
You can use any d-series head from 88-2000, even the sohc vtec ones. some will change your compression ratio though.
[Modified by thumpu77, 7:44 AM 9/24/2002]
Old Sep 24, 2002 | 07:54 AM
Default Re: Cylinder Head (91civic)
yes, I just need the head itself, can someone confirm this pls.. thanks
Old Sep 24, 2002 | 08:03 AM
USDM 4G VTEC's Avatar
if u wanna keep same compression ratio and performance i am going to tell u to stick to any 88-91 CRX/Civic Si head....they are all the same....
Old Sep 24, 2002 | 08:30 AM
HF2ZC's Avatar
I believe the head for the DX is the same as the Si, but the camshaft is different.
Old Sep 24, 2002 | 09:08 AM
SohcVtecCrix's Avatar
You would really want another Si head because it produces allot more compression than Dx head can..i believe its cause of the combustion chambers...You can tell if it is an si head or not my the stampings on the front it should say either Pm3/6 or Pm3/7.....please correct me anyone if i am wrong. IF you can try to get a 89 Si head or a 91 si head....those are the best years...just cause of the fact that the cams are higher lift than the 88.....And i recommend running the 91 crx si computer cause it makes the most power and the rev limiter is at 7500 rpm. IF you wanna know more just IM me on AIm or email me....hope this helped
Old Sep 30, 2002 | 07:46 AM
Default Re: Cylinder Head (SohcVtecCrix)
ok, I'm buying a cylinder head from my friend. How would I know if it's from an Si? It has a complete rocker arms and cams, is there a stamp or something? I see a PM6 stamp on it.. it'll try to post some pics.
Old Sep 30, 2002 | 08:11 AM
all honda heads have a stamp on the side of the exhaust manifold that says the ECU code.... for example... my STD head says PM9... an SI ehad should have PM6 stamped on it..... just look at the stamp...
BakedAlex
Jan 13, 2013 03:26 PM
stemiched
13
Jun 25, 2006 08:30 AM
DOHClessEF-9
Jan 2, 2005 01:41 AM
Broken Gearbox
Apr 5, 2003 10:48 PM
whagkangmakulet
Oct 15, 2002 05:40 AM
