Ordering pistons for a boosted ls/vtec setup. Which part number?
Old Jan 11, 2011 | 07:12 PM
low91rex's Avatar
Default Ordering pistons for a boosted ls/vtec setup. Which part number?
Hey guys I just bought a set of wiseco pistons and easgle rods, but Im not too sure on wich part number to ask for. Im guessing this one? K542M815. It says it gives a 9.3:1 - 9.8:1 Cr. That should be where Im looking at for boost right? But that says Its for the b18a/b block and head. Im using a b16 head so wouldn't the Cr be a bit higher? Thanks in advance for any input!
Old Jan 11, 2011 | 07:18 PM
low91rex's Avatar
Default Re: Ordering pistons for a boosted ls/vtec setup. Which part number?
http://cgi.ebay.com/ebaymotors/Wisec...#ht_4997wt_939
The setup I'm going with It shows you part numbers and their Compression Ratios.
Old Jan 11, 2011 | 07:47 PM
habib's Avatar
are you on a stock bore? the part number you gave is for a bore of 81.5, if you are on a stock bore then do k542m81
Old Jan 11, 2011 | 08:02 PM
low91rex's Avatar
I'm getting the block bored to 81.5. but will this be a safe Cr to be at? I don't want to get into the 8's because I think that a little too low.
How much compression does a b16 head add? Also if I order K542M815 will they have deep enough valve reliefs?
Old Jan 12, 2011 | 05:29 AM
habib's Avatar
You will be fine with that c/r. Are you running stock size valves?
Boostage
Jan 16, 2009 07:59 PM
7rrivera7
29
Jan 11, 2007 03:23 AM
97itr86
Nov 4, 2004 05:06 PM
