Ball Joint Maybe??
Old Jan 11, 2011 | 11:39 AM
AP14TW's Avatar
Icon2 Ball Joint Maybe??
My 90 Si has what I like to call a "shimmy" whenever I am turning to the left and putting a load on the right front, especially under acceleration. This happened after I installed a new set of shocks without using a fork splitter on the ball joints. I am thinking its a ball joint, which I have never replaced. Just wanted to ask before tearing this thing apart. Any way to figure out if it is the lower ball joint versus the tie rod end ball joint on the steering assembly? I have jacked it up and tried to shake the wheel/tire but it seems pretty solid. I know that is how to trouble shoot a bearing, so i think we are good there. Any help is much appreciated.
Old Jan 11, 2011 | 12:57 PM
BiG ChOr!Zo's Avatar
Default Re: Ball Joint Maybe??
this sounds really similiar towards my problem...have you checked the condition of both front lca bushings...!!!
Old Jan 11, 2011 | 01:50 PM
AP14TW's Avatar
no i haven't. never thought about that. Mine is really bad and shakes the wheel when i turn it.
Old Jan 11, 2011 | 03:16 PM
mine does the same...i narrowed it down to new front lca's since i put in new tie rods,rack and pinion,wheel bearings,front uca's,axles and ball joints and it never corrected the problem...!!!
Old Jan 11, 2011 | 03:34 PM
rd91sib18c5r's Avatar
Sounds like it coold be an axle, because you say it feels solid when
you shaked the wheel when it was off the ground.
Old Jan 11, 2011 | 08:01 PM
AP14TW's Avatar
Icon3 Re: Ball Joint Maybe??
Ha, btw... i put new axles in too.... hmmmm.
wgbm92
May 18, 2011 02:13 PM
CARMA_626
Feb 22, 2009 06:48 AM
teddy_dc2
May 19, 2007 05:09 AM
trianglegreg
Nov 15, 2006 05:01 PM
Armed Ferret
Dec 7, 2002 01:14 PM
