corrosion in coolant jacket after cleaning with purple power
Old Jan 10, 2011 | 07:45 PM
92lxsleeper's Avatar
Default corrosion in coolant jacket after cleaning with purple power
so i recently cleaned my b18b1 in purple power the other night and the engine came out awesome. i noticed tho that there is corrosion in the coolant jackets inbetween the sleeves and block. purple power said nothing about not using on aluminum so im curious as to if anyone has ran into this before, and what they used to remove it.
Old Jan 10, 2011 | 10:32 PM
farfrumugen's Avatar
Default Re: corrosion in coolant jacket after cleaning with purple power
i dont have any purple power handy at the moment but i always thought it said not to use on aluminum. it will even corrode steel if left to sit to long or if left long enough to evaporate its real bad. double check the label. i am sure my old bottle said not to use on aluminum.
adam
Old Jan 11, 2011 | 07:08 AM
it says to test it on a inconspicuous area, which i did with a rag, plus i clean my aluminum rims on my truck with it so i thought nothing of the sort would go wrong with soaking the engine in it. im thinking if i plug the coolant jacket that goes to the water pump i can fill it with carb cleaner, and if that doesn't work, i've heard to use bleach.
EJ8Squad919
Jun 22, 2014 09:04 AM
mikeszutu
Nov 24, 2008 11:25 PM
patastinky
Jan 21, 2003 05:43 PM
Duck Sauce
Nov 23, 2001 08:49 AM
