93 civic - making weird noise while in reverse
Old Jan 10, 2011 | 05:23 PM
dfJDM's Avatar
Default 93 civic - making weird noise while in reverse
i have a 93 civic with a ls motor
heres the issue, the front end is being redone slowly, so far i have done inner and outer tie rods and all new lca and uca bushings. now for the noise, when i got to reverse or turn in reverse, you hear this weird whine and grind. stops right when i stop. only does this in reverse and when i make turns at low speeds. prolly cant hear it while im going cause the car shatters alot still.
anyone got a clue what it maybe? i was thinking my axles...
Old Jan 10, 2011 | 06:22 PM
dfJDM's Avatar
Default Re: 93 civic - making weird noise while in reverse
bump.. anyone got an idea?
Old Jan 10, 2011 | 08:28 PM
civicdelsol33's Avatar
Id replace the wheel bearings next. The axles usually click when you turn and accelerate at the same time.
Old Jan 11, 2011 | 05:15 PM
dfJDM's Avatar
hmm, okay, will do
MatteBLK
Jan 19, 2015 11:34 AM
CaptRexKramer
Sep 27, 2014 05:39 AM
zfreak
Feb 9, 2009 10:50 AM
