S3OO ls/vtec help! car stalls sometimes and bogging at 2800
Old Jan 10, 2011 | 01:38 PM
jjt3009's Avatar
Default S3OO ls/vtec help! car stalls sometimes and bogging at 2800
Hi, to all i'm new in this forum, I'm a noob with hondata, I recently bought a Ls/vtec and it cames with Honda s300 the problem is, when i drive the car every day to my work sometimes after 10 mins of ride by highway when i make some stop car stalls or still at idle for a few seconds but after 3 or 4 seconds idle bounces betwen 1400 - low.. and then stalls... idk exactly what is the problem due to car makes it sometimes not always, somedays run smoth and perfect and sometims stalls on every stop. I don't know if it is a problem with temperature, tps, Please help me!. Im attaching a datalog of the car stopped and also im attaching the map of the car.
fyi i bought the swap on USA and now is running here on europe
let me know if its enough or what could be wrong thank you so much to all answers
Old Jan 10, 2011 | 02:20 PM
JDM JEFFREY's Avatar
Default Re: S3OO ls/vtec help! car stalls sometimes and bogging at 2800
Where the map and log?
Old Jan 10, 2011 | 05:55 PM
HAMOTORSPORTS's Avatar
More than likely the tune isn't great. Post the datalog of your a/f ratio's at idle and we'll take a look....
Old Jan 11, 2011 | 08:50 AM
jjt3009's Avatar
Good day, to all!
many many thanks for your repplies here you have the datalog and map
datalog
cars map
as i mentioned this I bought the swap and we've installed on my car, IDK if there is a problem with tps or something else
Old Jan 12, 2011 | 02:19 AM
jjt3009's Avatar
bump! any help? any S300 guru can help me??
Old Jan 13, 2011 | 09:22 AM
jjt3009's Avatar
Bump! help!
Old Jan 15, 2011 | 12:54 PM
jjt3009's Avatar
At least please tell me if everything is correct with TPS or MAP...
and if someone can have a look on my cars map i'd appreciate
Btw, I've here 3 more datalogs
cold start at morning
After highway
Cold start at noon
Old Jan 16, 2011 | 04:27 AM
jjt3009's Avatar
bump! 222 views... just a few posts.... plz help!
Old Jan 16, 2011 | 02:45 PM
HdeucedeuceA's Avatar
Sorry it says that I'm not authorized, so I can't look at them.
So you bought the swap here in the USA and you're in Europe, correct? What came with the swap, what is different from what the S300 was originally tuned for?
Old Jan 16, 2011 | 06:42 PM
v.i.gsr's Avatar
Whats the set-up...
Old Jan 16, 2011 | 07:07 PM
DDTECH's Avatar
hondata trash.
Old Jan 16, 2011 | 07:21 PM
hoffmanb16's Avatar
we can't see what you posted.....
Old Jan 17, 2011 | 09:24 AM
jjt3009's Avatar
sorry.. there you have
Cars map
Datalog Idle 1 min
Cold Start morning
After highway morning
Cold start at noon
there you have guys Idk why but trying to make datalogs hondata sometimes gets dc without any reason, note how rpm's bounces at low rpm on the datalog of cold start
idk if there is something wrong with my TPS sensor or map sensor....
I really appreciate your help
Btw, yes I've purchased the motor on Usa and we've made the swap here, so trying to imagine what can be wrong, we're having some problems setting idle, it was tightening cable (nobody is able to manage s300 around here)
many thanks in advance to all!
Old Jan 17, 2011 | 10:49 AM
What are the specs on the motor??
Old Jan 17, 2011 | 12:44 PM
jjt3009's Avatar
hi!
b18c1 block / pr3 head
blox stg 2 cams
Itr intake manifold
70MM TB
Rc injectors 440cc
fuel is 95 Ron here in europe i think equals to 91 US aki
please let me know if u need something else.... also... tps is ok? and what about map??
thx to all!
Old Jan 18, 2011 | 01:31 PM
jjt3009's Avatar
bump! for help!
Old Jan 18, 2011 | 03:09 PM
cruizinmax's Avatar
Your minimum idle speed is at 1300 rpm, the car always shows 1% throttle opening, the iac duty cycle is all the way up.
Check the tps voltage, lower the minimum idle speed down to what you want it to idle at, try playing with the IAC duty cycle to see if that has any effect on it.
Do you have a wideband on the car? What air fuel ratio does the car idle at?
Old Jan 23, 2011 | 05:46 AM
jjt3009's Avatar
Hi
no i don't have a wideband on the car =S, to be honest car runs rly great at high speed all my problem is idling or low speed, and i was reading and i found that maybe my problem is with my TPS, my mechanic here doesn't know anything about hondata and he was playing thightening the cable
my problem is my tps? could be solved scaling the TPS?
thank you so much for help!
Old Jan 23, 2011 | 07:33 AM
mtber's Avatar
Originally Posted by jjt3009
Hi
You might as well drive blind folded down the highway without a wideband.
Old Jan 23, 2011 | 07:40 AM
jjt3009's Avatar
sorry i don't get you.... :S the reason why i don't have the wideband is because i didn't tune the car, swap comes with ecu and everything just to plug and play... the problem is my iddling...
thx!
Old Jan 23, 2011 | 04:15 PM
cruizinmax's Avatar
You can't adjust the idle by tightening the throttle cable. The throttle has to close all the way or the car will not idle correctly. You NEED a wideband and a competent mechanic to fix the problem.
Old Jan 23, 2011 | 11:02 PM
Turn the car on but don't start it, go to parameters, then TPS. You can see the values under TPS scaling; minimum/maximum. For the minimum reading make sure your foot is off the gas and hit read. The percentage should change. Then put the gas to the floor and hit read for the maximum. The percentage will most likely change. Then upload and save the calibration.
The rest should be done by a tuner. I'm not familiar with the B-series so I can't tell you how those cams like to idle.
Old Jan 24, 2011 | 12:29 AM
jjt3009's Avatar
thank you!!!!
so do you think that there is something wrong with my TPS?
Old Jan 24, 2011 | 10:38 AM
jjt3009's Avatar
Hi I scaled my tps, and as you said the percents are now different
first i got
minimum 0 / maximum 104,6
now i have
minimum 1,94 / maximum 105,08
I think there is something wrong with my tps...
Old Jan 25, 2011 | 02:41 PM
cruizinmax's Avatar
I don't think there is anything wrong with your tps but if your throttle cable is holding the throttlebody open it will never read 0 and will never idle correctly. If the throttle is closed all the way you need to make sure the voltage when it's closed reads the correct amount.
Someone correct me if I'm wrong but I think even if you scale the TPS to read 0 and 100 percent in hondata the voltage does still have to be adjusted correctly, right?
