sensor wire diagram
96 accord l swapped in a h22 but some of the sensor not positive where they hook up to like map,tps,etc the wires on connectors are dif colors so lm trying to identify them that way. anyone know of a diagram explaining which sensors with wire color go where? need ASAP
Don't guess. Look at the block stamp serial number, as well as the year/month stamp on the head. That will tell you which engine you have. Then report that back to me for my chart.
If you don't have a Helm's, get a Helm's.
Most of the connectors can only go onto one sensor and unless you take your harness completely out of the tape it's really hard to mess up.
You can mess around with hondaautomotiveparts.com and look at different diagrams for your shell to see what connector is what. Just plug in your year and car trim and just start looking through all the parts.
yea but egr,tps, and map all have the same type of connector. l have a good idea which may be which but would like to be positive so l have less troubleshooting later
