JE Pistons Provides An Education In Piston Terminology
Golden Eagle Mfg will build your engine with JE pistons.
Call or pm for pistons or engine build prices
by Andrew Wolf on January 3, 2011
0Comments
Have you ever been carrying on a technical conversation with someone that’s using terminologies that you don’t particularly know or understand and wish you had a little cheat sheet stored away in your brain or a lighting quick smart phone to look it up? This can often be the case when talking car parts. Take a piston for example: while their function to internal combustion is relatively straightforward, many elements make up the top, sides, and insides of a piston. And sure, anyone that’s ever built an engine knows exactly what each of those terms point to, but not everyone has that experience or knowledge.
Fortunately, JE Pistons has provided a nice little cheat sheet that even if you can’t manage to store in your brain, you could always print out and carry around with you. The Piston Terminology section on their website breaks down each area of a piston with tags pointing to the various elements to provide a little education in what all those big and little words mean.
The side view shows the deck, dome height, lands, forced pin oilers, lock grooves, skirt and other elements, while the side cutaway view points out the compression height distance, valve pocket, valve angle, pin bore center, gauge point, and valve pocket depth. Finally, the top view shows us things like the intake and exhaust centerline out, intake and exhaust valve relief, and the valve stops. Armed with this information, never again will you be lost when in conversation with an engine builder or piston manufacturer. So, get to studying.
JE PISTONS
Golden Eagle Mfg. is proud to offer JE pistons
Contact us here at G.E. for all you engine build services
0Comments
JE PISTONSGolden Eagle Mfg. is proud to offer JE pistons
We are proud to offer CP pistons now for your next engine build.
Also custom piston dome and side skirt coating service for your pistons.
You can trust us here at Golden Eagle to lift you up on our wings.
Coast to coast G.E. boosts the most.
Street Proven, Track Tested, & Race Inspired
PM, call or e-mail for the best prices.
S2000 HIT THE WALL HARD BUT DRIVER WAS OK
http://www.nyce1s.com/forum/showthread.php?t=2643
Looking for a price on these pistons http://www.jepistons.com/Products/302410.aspx.
part number 302410
part number 302410
95c1v1cs1
Jul 28, 2004 09:44 AM
