Pro2 vs. Pro3 on full build H22A eingine??
Old Jan 10, 2011 | 12:51 AM
hingi's Avatar
Default Pro2 vs. Pro3 on full build H22A eingine??
i have the Pro2 at the moment and think about Pro3 cams.
I use the engine 60% on street (dayli drive) and 40% circuit track-race.
engine mods:
E85 fuel (on go)
ENDYN head
ENDYN block
12,0:1 compr.
3" exhaust
i need good midrange and top-end (max. 8200rpm)
is it possible to use the Pro3 or not?
other cam?
thanks
Old Jan 10, 2011 | 02:54 AM
crazes's Avatar
Moderator
Default Re: Pro2 vs. Pro3 on full build H22A eingine??
i would stay with pro2's since you will be driving it more. I think the idle will be to much for you if your street driving, but pro 3's will give you alot more power if you have the suppprting mods for them
Old Jan 10, 2011 | 06:02 AM
koczeka's Avatar
Why dont U ask and trust Larry?
Old Jan 10, 2011 | 02:12 PM
flesh199's Avatar
x2
Old Jan 10, 2011 | 02:18 PM
SergEK's Avatar
engine mods:
E85 fuel (on go)
ENDYN head
ENDYN block
12,0:1 compr.
3" exhaust
other cam?
thanks
Borrow a set and see what happens - with a built motor and headwork you can afford to raise the revs and make even more power on the cams your already running - pro 3s would make more power in VTEC where Im sure you want to be in on the track.
Edit: with that comp and built motor I would say the Pro 3s are a no brainer - the idle might be an issue but Im sure you can tune the maps/raise the idle speed to compensate
Old Jan 15, 2011 | 07:59 PM
nus_dogg's Avatar
x2!
hingi
11
Jun 23, 2011 10:30 PM
mozzandherb
Jun 22, 2011 07:55 AM
kornkid21792
Sep 8, 2009 06:45 AM
kornkid21792
Aug 23, 2009 09:08 AM
Daysleeper
38
Mar 16, 2004 07:20 PM
