problem with lights on 91 ef
Old Jan 9, 2011 | 08:13 PM
tidalwavez's Avatar
Default problem with lights on 91 ef
i am having problems with my back tail lights not working. The wiring looks just fine, Ive replaced the bulbs and still nothing. The brake lights work, but there aren't any lights on when my foot is off the break. Also my dash lights aren't on anymore, only lights that show up is the lights that show when the brake is on. Im guessing this might be a fuse problem? but i am not sure, im semi new to all this car stuff, this is my first built up car, so any help would be appreciated!
thanks!
-matt
Old Jan 9, 2011 | 09:12 PM
tonythetuner®'s Avatar
Default Re: problem with lights on 91 ef
Check the fuses lol....
Old Jan 11, 2011 | 09:07 AM
tidalwavez's Avatar
ight, i dont have a manual for my car, and im having trouble finding the right fuse diagram, any chance someone knows what fuse goes to the lights?
Old Jan 11, 2011 | 02:30 PM
choocko's Avatar
Check your fusebox inside the car.There's one in the car usually in the inside by the driver side. There is also a main fuse box check that too. Please make sure you check the right amp voltage. Ex.. if it said 30 make sure 30 is on the right spot. Other than that check ground connection. I had a similar problem, and mine was because my ground wire kept coming loose. Good luck
Old Jan 11, 2011 | 04:52 PM
netfreak's Avatar
The fuse that controls that is the box under the dash. Mine went and fried the wiring a bit too.
Old Jan 12, 2011 | 12:24 AM
RockinDaEf9's Avatar
I had the same problem and it was my fuse. Just take it to a electric shop i got charged 28 bucks and its been working ever since
defensa24
Mar 8, 2011 06:45 AM
slammed em1
Jan 23, 2010 09:26 PM
Capt. Jimbo McSubipants
May 21, 2009 09:15 AM
chickenandpickles
Apr 25, 2005 05:20 AM
NiceDc2r
May 13, 2004 09:42 PM
