91 Hatch Hub
Old Jan 9, 2011 | 05:02 PM
jasonbabin's Avatar
Icon2 91 Hatch Hub
alright so my hub on the drivers side of my car is trashed and the parts through honda have been discontinued (i'm a tech for honda) so i was curious to know if any other knuckle/hubs would work on my car cause at this point my car is stuck on my rack at work and it sucks
Old Jan 9, 2011 | 05:05 PM
jdm ef8 89's Avatar
Default Re: 91 si hatch
I believe the DX are the same part number/size as your si hubs/knuckles, but the HF wont work because of smaller size axles. I heard STD wont work but Dx will I dont know the difference between the two.
Old Jan 9, 2011 | 05:16 PM
sh!ft's Avatar
Who the fack changed my title?!
if you really wanna try it, i think the eg assemblies are similar as well
Old Jan 9, 2011 | 05:23 PM
jasonbabin's Avatar
according to the parts guy at my shop honda no longer makes hubs for any of the 91 civic models..... and will eg knuckles work with out thrashing something else
Old Jan 9, 2011 | 05:28 PM
sh!ft's Avatar
id wait for the more experienced people to chime in. clipsed? chorizo? manny? where yall at?
Old Jan 9, 2011 | 05:34 PM
jasonbabin's Avatar
i've also heard of using 90-93 teg front assembly's (calipers, rotors, knuckles,) just don't know if my cv shaft will fit properly and not completly throw my alignment off we do have an alignment rack at work but i don't know if the angles will be close enough to make work
Old Jan 9, 2011 | 05:36 PM
jasonbabin's Avatar
and i don't know if i can use my si rotors and calipers with that set up if i can't find the whole swap in a short amount of time because it is too cold to ride my bike everyday
Old Jan 9, 2011 | 05:53 PM
sh!ft's Avatar
gotta go to work, ill be back later tonite, ill converse with you when i get back.
Old Jan 9, 2011 | 05:56 PM
KINGVEM^^ED6's Avatar
why dont u try a junk yard/salvage yard
Old Jan 9, 2011 | 06:01 PM
jasonbabin's Avatar
tried the ones around here the only hatches they have are completly stripped and my buddy has a crx si but the hub was to small for the cv shaft to go into
Old Jan 9, 2011 | 06:28 PM
CRX-Kid11's Avatar
i swapped 92 eg si knuckles onto my crx and they worked good, everything appeared the same by eye, didn't throw alignment way outta spec or anything, i did for brake upgrade and cause mine is a hf with smaller hubs for my swap, just unbolted and bolted egs on ull be fine with those
Old Jan 9, 2011 | 10:06 PM
hatchet_honda's Avatar
junkyard orrr ebay orrr craigslist..hows the hub trashed? what happened to it? do you need the whole knuckle orrr what
Old Jan 10, 2011 | 05:13 AM
CRX Toad's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/90-four-door-ex-hub-replacement-interchange-1855338/
http://www.performanceforum.com/wesv...nda/index.html
Old Jan 10, 2011 | 02:35 PM
Jockone's Avatar
Default Re: 91 Hatch Hub
Sounds like time to upgrade to 90--93 integra knuckles and brakes.
Old Jan 10, 2011 | 02:42 PM
Frazzo203's Avatar
The da hubs have always worked in the past
Old Jan 10, 2011 | 02:47 PM
Jockone's Avatar
Where are you located? someone near you might have what you need.
Old Jan 18, 2011 | 04:02 PM
jasonbabin's Avatar
i'm located in louisiana but i did find a complete da shell that i am going pick up this week for a very expensive $140 with title lol so it should be good again in a week are so
historic4thewin
10
Jun 10, 2013 03:12 PM
nex_episode_kodiak_crew
May 18, 2009 03:28 PM
Dainbramage
Aug 6, 2004 06:55 PM
Red_Si
11
Dec 21, 2003 09:54 PM
sooboss
Mar 3, 2003 05:48 PM
