B series tutorial
Old Sep 23, 2002 | 10:57 PM
spettinger's Avatar
Default B series tutorial
just to make things perfectly clear......
all B series motors will bolt in using the same motor mount kit. whether it's place racing, hasport, HCP, custom, whatever. the crv B20 might be different, get the mount from a B16 or ls motor.
the shift linkage should also be purchased from the same company supplying the mount kit.
the B18/ B20 motors are 7 millimeters taller than the B16. they require a longer header (such as the header for a GSR, DC sports JDM integra replica) and the valve cover will sit higher in the engine bay due to the taller block.
there is not that much weight to be saved from stripping the interior. in the back of a CRX, there is about 15 pounds of plastic side panels and cargo covers. don't think that stripping your car will have you running lower times.
TRANSMISSIONS: 88-91 civic/crx's require CABLE transmissions. hydraulic transmissions from 92 up do not currently have a bolt in kit and are difficult to fit without a good deal of knowledge. either get an ls or B16 trans from 88-91.
quarter mile times: these are difficult to predict. go find out for yourself.
i hope to stop a lot of redundant questions. if someone had made a post like this when i was learning about cars, i would have saved a lot of people's time.
Old Sep 24, 2002 | 01:36 AM
ProjectBeater's Avatar
Default Re: B series tutorial (wreckedhatch)
Amen... there's small stuff you missed but to answer MOST of the redundant questions you get
Old Sep 24, 2002 | 04:12 AM
Monty's Avatar
Default Re: B series tutorial (ProjectBeater)
And dont forget to check out http://www.hasport.com for some great info on wiring and axles. its in the tech section.
And remeber when your making clearance for the altenator and folding down the lip on the rear crossmember, you might as well cut off that damn front mount. That thing was a pain in the ***. Why isnt that in the instructions?
Monty
Old Sep 24, 2002 | 04:13 AM
Soled Out's Avatar
Post like this should be stickied
Old Sep 24, 2002 | 05:52 AM
audioroach's Avatar
Default Re: B series tutorial (Boosted EF)
Thanks for shedding some light....Knowledge ispower
Old Sep 24, 2002 | 06:15 AM
SuperCivic's Avatar
good idea there man..hopefully people will read this. the difference w/ the B20 is you have to change the driver's side mount bracket on the motor w/ one from a b18 or b16..the stock b20 won't work. as for the b20 needing a longer header, i used my stock b16 exhaust manifold, which bolted up fine to the exhaust i had built for my b16.
Old Sep 26, 2002 | 02:20 PM
spettinger's Avatar
Default Re: B series tutorial (SuperCivic)
really? your B16 manifold worked? that is interesting. i thought that with the taller block they required the longer headers. oh well.
the reason i put that up was because i was so damn tired of people posting---
will a B16 fit in a crx? how bout an ls motor fitting into a hatch? can i use my stock axles, shift linkage, steering wheel, carpet, rims?
Old Sep 26, 2002 | 03:53 PM
Malgerus's Avatar
Hahaha! Good tutorial mang. However, I do think that stripping the rear can make quite a difference, if you also take out the tar and spare tire Made a difference for me
Old Sep 26, 2002 | 04:22 PM
EL Vap133's Avatar
lol, it must have gooten to you huh?
Old Sep 26, 2002 | 07:38 PM
Chris's Avatar
Default Re: B series tutorial (Vap133)
THANK YOU x100!!!!
I didnt know about the Crossmember.
Ill be getting my B16A for my 91 hatch tomorrow! S1 tranny, so no problems with hydraulics there!
Hasport will be doing my harness... interesting about the shift linkage.
Old Sep 26, 2002 | 08:01 PM
dlric's Avatar
why would u feel necessary to put this remark in..it has nothing to do with b-series. those that want to strip their cars can strip their cars. if you gut all the interior, the carpet, the tar underneath, the heater and all that sh*t you will lose a pretty good amount of weight. i've done it to two diff crx's and the butt dyno agrees with me. i got my crx si down to 1980lbs and i only gutted the interior, the tar and kept everything under the dash. my hf is now COMPLETELY GUTTED...i have a driver seat and a dash..thats it. you CAN NOT get around physics man. less weight = go faster.
Old Sep 26, 2002 | 08:03 PM
StorminMatt's Avatar
A couple of things. First of all, the B18A/B18B/B20 are not taller than the B16A. The block may be taller. But the head is shorter. It all comes out to a motor that is of about the same height. As for brackets, these are different with ANY newer B-motor (1992+ SIRII B16A and 1994+ B18B as well as B20). If you are using one of these motors, you need the 1990-1993 Integra driver's side and rear transmission bracket to make the swap work.
Old Sep 26, 2002 | 11:52 PM
riceboy's Avatar
Default Re: B series tutorial (StorminMatt)
My LSVTEC (B18A1/B16A1 cleared the stock hood (barely) in my 90 SI CR-X the oil pan sat real low to the ground at minimal drop.
Some things I would liek to throw in is that if you are building an LSVTEC/CRVTEC, use head studs, but aftermarket opistons and rods while th motor isi open, sleeve it is you will boost it or you will regret it.
My humble opinion is that the LS tranny is the best for the CR-X, even with the gears, the car is so light, it dosen't matter.
I'm gonna save this thread for quick answers to repeated questions. Anyone care to add to their most hated/want to answer for the last time topics?
Old Sep 27, 2002 | 03:30 AM
Monty's Avatar
If you can find an actual SIR (gold) shift linkage it will work with b16 crx. Well in mine it did. I have the XSI rear bracket, and Hasport billets! I wish I would have known before the swap though. I was stressing that I was going to have to have hasport fed ex me their shift linkage for $$$
Heres a replacement parts list for b16.
Part Honda # Source
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Pump O ring (Does not come with Pump) 91302-PF0-003 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Bitch Pin Shift Linkage 91 crx si
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Valve Cover Gasket 12341-PR3-000 94 - del sol
V-TEC solenoid valve filter O ring 15825-P08-005 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose (trim) need a hose clamp 19501-PR3-000 92 - integra gsr
Lower Radiator Hose (trim) need a hose clamp 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
I also have this list in excel format with dealer prices if anyone wants it. No one handed me this list down, but I wish I would of had it before starting the swap.
Monty
1991 CRX SI
1991 B16 / J1 (almost running!)
[Modified by Monty, 12:34 PM 9/27/2002]
Old Sep 27, 2002 | 04:24 AM
Home Skillet's Avatar
Default Re: B series tutorial (D Series Pwr!!!)
or add it to your notepad
Old Sep 27, 2002 | 07:27 AM
STK B16's Avatar
Default Re: B series tutorial (Monty)
Old Sep 27, 2002 | 08:54 AM
Proper's Avatar
Great info!
Old Sep 27, 2002 | 09:22 AM
riceboy's Avatar
Monty , I have always used B17A1 top end parts/gaskets for replacements, and they fit perfect everytime.
Old Sep 29, 2002 | 01:57 PM
spettinger's Avatar
Default Re: B series tutorial (riceboy)
as for gutting the interior, i would not do it again. i had to remove my front carpeting and sound deadening because of a bad fuel leak, so now all i have is floormats. i would like to get some front carpet again. i removed my rear interior parts except for the speaker brackets and i would put it back in if i still had the stuff. i pulled the panels out to put in a roll cage that i still haven't welded in. it just sits in my basement. you do drop about 50 or so pounds from removing everything in the car, but i hate the look of that. if you feel the need to strip your car, that is your choice. i just really dislike the look of a gutted crx because crx interiors (90-91 si's anyway) look so nice.
where the hell did someone hear that GSR/ B20 heads are shorter??? they are all very similar castings.
[Modified by wreckedhatch, 10:58 PM 9/29/2002]
Old Sep 29, 2002 | 02:39 PM
dlric's Avatar
haha. it does increase interior noise a decent bit. unfortunately a lot of older crx interiors are crap anyway..scratched up, etc. so what the hell. i like the look of a gutted crx. #1 its a small car so it gives u more elbow room. u can also haul around more stuff in the back with those useless interior pieces out. and like i say. less weight go faster. thats all i care about.
Old Sep 30, 2002 | 08:33 PM
Actually, even the B18A/B18B labors with the LS transmission. I have found that only the B20 can really pull decently with an LS transmission.
Old Sep 30, 2002 | 08:52 PM
Francois's Avatar
But the problem lies when kiddies doesn't take the time to search and read.
As for stickies..you have my vote....and we should do one for the rear brake(disk swap) too!
Old Sep 30, 2002 | 09:46 PM
QTKEG6's Avatar
Default Re: B series tutorial (Francois)
amen to that
McMahon
Apr 25, 2013 03:11 AM
conantech
10
Apr 5, 2011 09:57 AM
Tommy_Gunns
Jun 19, 2002 11:33 AM
dumbchild
Feb 27, 2002 02:41 PM
