Suspension & Brakes Theory, alignment, spring rates....
Replacing Trailing Arm Bushing 97 Honda Civic - No special tools
Old Jan 9, 2011 | 09:53 AM
happyhondgirl's Avatar
Default Replacing Trailing Arm Bushing 97 Honda Civic - No special tools
We just bought a 1997 Honda Civic LX. Needs alot of love and parts replacements, so money for a special tool is not in the budget! However, no special tool is needed for replacing the rear trailing arm bushings! Temperature outside is a chilly 32 degrees F....we tried everything, then I picked up the small hammer (small roofing hammer) and tried tapping it out evenly along the edges....it worked, tapped that little booger right out of there! The new one went right in the same way...tap, tap, tap on the left and tap, tap, tap on the right until it is in up to the line!
A 10 minute job each side! Amazing! It could've been the temperature outside, it could've been the PB blaster we sprayed on it to soften it up some....but the new ones are in and all we used was a small hammer!
I just thought I'd share that with all of you....you DON'T NEED the special tool!
Old Jan 9, 2011 | 09:59 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Replacing Trailing Arm Bushing 97 Honda Civic - No special tools
Thanks for sharing
Old Jan 9, 2011 | 10:10 AM
BryanM.'s Avatar
Resident Gearhead
Sometimes they pop out with little trouble, other times they can be a real pain.
Usually for me they are a real pain.
Old Jan 9, 2011 | 10:48 AM
98civdx's Avatar
Master Detailer
What you just said has been said a million times, well now a million and 1.
But what mcvtec said is very true, mine were a complete pain, i ended up getting pissed off and droping the trailing arm.
Oh yea, you know you rent the tool for free right? You pay depost and it is returned when the tool is.
twospoon
Honda Civic (2006 - 2015)
Apr 11, 2018 09:16 AM
TOP91
Aug 21, 2011 05:15 PM
DennisWaller
Suspension & Brakes
Jul 22, 2010 09:28 PM
